HEI electronic ignition discussion
https://slantsix.org/forum/viewtopic.php?t=28732
Page 35 of 35
Author:  Rick Covalt [ Sat Feb 07, 2026 1:48 pm ]
Post subject:  Re: HEI electronic ignition discussion
What kind of modules are you running? GM? Chinese? Do you have a good ground on the system. And what voltage are you seeing at the module itself.
Author:  tattoosteve99 [ Mon Feb 09, 2026 1:03 pm ]
All good questions that I hadn’t thought about. I’ve run grounds all over the charging and ignition system so I don’t think that should be an issue. Mostly run the standard lx301 I guess Chinese modules. Not sure on the voltage so I’ll check that and get back to yall.
Author:  Rick Covalt [ Mon Feb 09, 2026 4:35 pm ]
I usually run a ground from the mounting screw of the module to the battery ground. Yes just verify your voltage at the module is not dropping off.
Author:  SlantSixDan [ Mon Feb 09, 2026 7:59 pm ]
Make sure the module is well heat-sunk, and make sure your line voltage with the engine running isn't spiky or too high.
Author:  Rick Covalt [ Tue Feb 10, 2026 6:42 am ]
Yeah! What he said too! :D :D
Author:  tattoosteve99 [ Tue Feb 10, 2026 11:42 am ]
I know it’s not to high as it only runs about 13 to 13.5 volts after the relay upgrade. I usually use heatsink paste instead of the line they supply unless that might be my problem?
Author:  Rick Covalt [ Tue Feb 10, 2026 1:00 pm ]
That should be fine.
Author:  MadScientistMatt [ Tue Feb 10, 2026 4:23 pm ]
13 to 13.5 is a decent battery voltage number when warmed up.
Author:  BUCKET 636 [ Tue Jul 07, 2026 2:59 pm ]
Long time no posts from me .
Looking at doing this conversion on another car .
Would this HEI Module work .
https://www.ebay.com.au/p/244608173?srs ... a3NxPf3qk5
I can't see it mentioned in Dan's retrofit discussion .
Cheers ,
Bucket
Author:  SlantSixDan [ Tue Jul 07, 2026 4:49 pm ]
Yes.
Author:  BUCKET 636 [ Tue Jul 07, 2026 10:04 pm ]
Yes.
Thanks Dan .
Page 35 of 35 All times are UTC-07:00
