GodsRods Duster II
https://slantsix.org/forum/viewtopic.php?t=39102
Page 37 of 47
Author:  Rob Simmons [ Tue Jun 05, 2018 6:45 am ]
Post subject:  Re: GodsRods Duster II
I finally got around to replacing the last piece of yellowed lexan on the Duster. Now I'll be able to see out the back finally. :lol:
Author:  slantzilla [ Tue Jun 05, 2018 8:42 am ]
:D :D :D :D
Author:  Rob Simmons [ Tue Jun 12, 2018 5:51 am ]
I was hoping to fiddle with the Duster a little bit before the Motormile race this weekend.... Not sure that's gonna happen though... I will likely do my typical "Show up with a non-running car and beg for help" thing I've been teased about over the years (for good reason).
It runs okay and I've even changed the oil, flushed the cooling system, bled the brakes, replaced the rear windshield and sprayed a little paint on a couple spots.
I guess we'll see y'all Friday (hopefully, if I finish something at work by Thursday).
Author:  Dart270 [ Tue Jun 12, 2018 6:38 am ]
Looking forward to it!
Author:  Rob Simmons [ Sun Jun 17, 2018 6:25 am ]
The Duster is running nice and consistent again. 9.00-9.10 pass after pass. The driver can’t cut a light yet, but he’ll keep looking for the tree. Too cautious not to redlight.
Another day of racing today. :D
Author:  Rob Simmons [ Mon Jun 18, 2018 7:50 am ]
Another very successful race weekend for the Duster. It made 13 passes over the three days of racing with every pass between 9.00 and 9.18. I adjusted the dial based on the weather and it ran pretty much what I expected every time. The heat played the biggest factor in the car being off the dial. The most it was off was the final race against Rick Covalt in the semis when we both slowed down. It was only off by .0624.
I need more seat time to be able to figure out my starts and cut better lights, but I won the race Saturday and was third on Sunday.
Rick Covalt beat me Sunday in a really great race. He dialed 9.01 and I dialed 9.10. We cut identical lights. We were both off the number due to the heat, but he was closer to his dial by .0047! :shock: If ya gotta lose, that's the way to go down swingin'! :D
Looking forward to Wilkesboro next month!
Author:  Rob Simmons [ Thu Jun 21, 2018 8:08 am ]
Here is a link to the semi final round between me and Rick. We had identical reaction times and he beat me by .0047! Closest race of the weekend. Thanks for posting this, Ryan!
https://photos.app.goo.gl/uc76bvnDcpUyUbJC7
Author:  Rob Simmons [ Fri Jun 29, 2018 1:34 pm ]
I've fiddled with the Duster a little this week. I replaced the fuel cell and cleaned up the passenger door and started to re-mount the window. The fuel cell replacement was good for about 12 lbs of weight savings and I was able to cut and scrape about 5-6 lbs out of the door.
Fuel cell before:
Fuel cell after:
Door stuff:
Author:  Badvert65 [ Sat Jun 30, 2018 3:15 pm ]
80lbs from just the one door? That is a really interesting door latch pull. I had never considered something like that, but I don't think you could get any lighter than that. Do the doors feel stiff enough with the inner skin removed.
Author:  Dart270 [ Sat Jun 30, 2018 9:16 pm ]
Must be both doors, or some other stuff too. Doors will be flexible, but still useable with all that gone. My Project V is about like that, with a bit more meat left.
Author:  Rob Simmons [ Sun Jul 01, 2018 6:36 am ]
I wouldn’t be surprised if it is now 80 lbs lighter than when it left the factory. :lol:
(The scale was set for ounces. )
I did go too close to the edge when I cut out that last bit of metal though. I should have left a little more of a lip. The door now flexes a little more than I would like. I may try to put some cross wires in it to see if that gets it back to being more rigid. It is useable as it is. It just flexes some.
I got the wire door pull idea from Seymour. Not nearly as well executed, but that’s how us Posers roll. :wink:
Author:  Rick Covalt [ Sun Jul 01, 2018 11:43 am ]
You trying to beat me Rob? takin all that weight out! Don't make me put in my 4.56 gears!!! :D :D
Author:  slantzilla [ Sun Jul 01, 2018 12:44 pm ]
I've got some 5:38's if you need them Rick. :mrgreen:
Author:  Rick Covalt [ Sun Jul 01, 2018 1:22 pm ]
Nah I kind of like the 3.91's! I never shift out of second in the 1/8th. :D :D
Author:  slantzilla [ Sun Jul 01, 2018 1:39 pm ]
My junk always liked 3.91's, especially with the hose on. The '68 has 4.10's in it. I doubt I will ever change them unless they break. :D
Page 37 of 47 All times are UTC-07:00
