Off-Kilter Racing (Lemons style)
https://slantsix.org/forum/viewtopic.php?t=63114
Page 40 of 42
Author:  slantzilla [ Mon Dec 02, 2024 5:49 am ]
Post subject:  Re: Off-Kilter Racing (Lemons style)
Very cool Mater! :mrgreen:
Author:  Charrlie_S [ Mon Dec 02, 2024 7:35 am ]
Is that one of those experimental 6 speed transmissions in the car?
Author:  Rick Covalt [ Mon Dec 02, 2024 11:34 am ]
Yeah! What Charlie said. I thought all floor shifters had a linkage hump? I must be wroooong again! :D :D Good luck rebuilding! :D
Author:  Rob Simmons [ Tue Dec 03, 2024 4:51 am ]
I’m told it’s the 3 speed. I don’t know about the mounting position, but I have seen the shifter style before. I believe it’s a Toad only version designed to clear the bench seat.
The shifter will stay! Whether we use a 4…5…6 speed or an automatic, we’ll fabricate it to work. :wink:
Author:  slantzilla [ Tue Dec 03, 2024 7:47 am ]
Isn't that shifter called the Twisted Snake or some such thing? I think it's a 1 year only thing. :oops:
Author:  Rob Simmons [ Tue Dec 03, 2024 12:34 pm ]
SlantSixDan to the white courtesy phone, please… :lol:
Author:  Rob Simmons [ Tue Dec 03, 2024 5:50 pm ]
I found some information on Curbside Classics that indicate the shifter was in 60-61 Valiants.
Author:  Greg Ondayko [ Thu Dec 05, 2024 6:26 am ]
The "charmed snake shifter" was available for '60-'61 Models only.
Some additional documentation
It appears that all of the 3-speed transmissions for '62 were column shift only, again one of the many subtle changes that were implemented for the 1962 model year.
I do not believe the hump would have been implemented until 1964 - because the 3 speeds before that did not have a need for the shifter and rod arrangement like the a833 does.
The Charmed Snake Shifter comes with a unique Transmission cross member that mounts the simple shifter to the crossmember itself, then the rods run to the 3 speed levers from there.
The shifter comes right through the floor pan from the cross member. It's quite a different setup than the typical '64 and later floor-shifted A bodies that we are used to.
I doubt Dan will answer the courtesy phone in this section of the forum, but he does know a lot of these sorts of things.
Author:  Rob Simmons [ Fri Dec 06, 2024 6:55 pm ]
Thanks Greg! :mrgreen:
Author:  Rick Covalt [ Sat Dec 07, 2024 4:42 am ]
the 3 speeds before that did not have a need for the shifter and rod arrangement like the a833 does. quote]
I didn't know that?
Author:  slantzilla [ Sat Dec 07, 2024 6:58 am ]
See? I knew it was some weird snake crap. :mrgreen:
Author:  Rob Simmons [ Mon Dec 09, 2024 6:09 pm ]
:lol: :lol: :lol:
Author:  Rob Simmons [ Thu Dec 12, 2024 7:38 pm ]
I picked it up this morning…
Author:  Rob Simmons [ Sun Dec 15, 2024 4:57 pm ]
It’s a little further gone than the first ToadRacer, but I think it will work.
I’ll get up under it and check the rust when I get it home.
Author:  slantzilla [ Sun Dec 15, 2024 8:26 pm ]
You ready for the Daytona now too? :mrgreen:
Page 40 of 42 All times are UTC-07:00
