| windage tray https://slantsix.org/forum/viewtopic.php?t=15912 |
Page 5 of 5 |
| Author: | gmader [ Wed Jul 19, 2006 2:51 pm ] |
Hi KJ, Any timeline on the windage tray? thanks, Greg |
| Author: | Kevin Johnson [ Mon Jul 24, 2006 6:40 pm ] |
Quote: Hi KJ,
Hi Greg, Any timeline on the windage tray? thanks, Greg Not for at least another month -- I just got another big order from a distributor that is going to swamp me for the next few weeks. One thing I just offered to someone in an email is a sheet of directional screening. It is something you can trim and then attach to the interior of your pan and it works quite well. I can explain how to orient and attach it securely. Kind regards, Kevin |
| Author: | sick6 [ Tue Jul 25, 2006 12:33 pm ] |
Quote: One thing I just offered to someone in an email is a sheet of directional screening. It is something you can trim and then attach to the interior of your pan and it works quite well. I can explain how to orient and attach it securely. Kind regards, Kevin check your private messages kevin. I have bought a house so I have been moving. I haven't heard back from you since the patent application. |
| Author: | Kevin Johnson [ Tue Jul 25, 2006 1:49 pm ] |
Quote: Quote: One thing I just offered to someone in an email is a sheet of directional screening. It is something you can trim and then attach to the interior of your pan and it works quite well. I can explain how to orient and attach it securely. Kind regards, Kevin check your private messages kevin. I have bought a house so I have been moving. I haven't heard back from you since the patent application. I replied to your new email address. |
| Author: | panic [ Tue Jul 25, 2006 4:06 pm ] |
I agree with Charrlie_S - it works, YMMV, but is it good value for money if your budget is limited? Personal choice. Some ideas for those with some fabricating skills. http://victorylibrary.com/mopar/baffle.htm |
| Author: | Kevin Johnson [ Tue Jul 25, 2006 5:49 pm ] |
Quote: I agree with Charrlie_S - it works, YMMV, but is it good value for money if your budget is limited? Personal choice.
Good link.
| Author: | panic [ Tue Jul 25, 2006 7:03 pm ] |
The tray itself is absolutely a bargain, but for someone with a 9-5 installation means a day off, center link, pan down, cleaning, scraping, gaskets. I lumped 'expensive" as the total amount of time/trouble/money to install it as a separate project. If you already have (or will) just do it. |
| Author: | Kevin Johnson [ Tue Jul 25, 2006 8:14 pm ] |
Quote: The tray itself is absolutely a bargain, but for someone with a 9-5 installation means a day off, center link, pan down, cleaning, scraping, gaskets. I lumped 'expensive" as the total amount of time/trouble/money to install it as a separate project.
Understand completely.
| Author: | featherduster76 [ Fri Jul 28, 2006 3:05 pm ] |
If you come up with a windage time/date or etc Id like to know of it also |
| Page 5 of 5 | All times are UTC-07:00 |
