| Rob's 1981 Dodge Challenger https://slantsix.org/forum/viewtopic.php?t=46322 |
Page 5 of 61 |
| Author: | Rob Simmons [ Sun Feb 26, 2012 10:55 am ] |
Late last night I was at a stopping point on the Duster (Next step is to fire it up! I have a feeling that the exhaust and the shield will want to occupy the same space... I can't tell for sure until the engine is in, but then it will be harder to install the shield... I think I'll go ahead and install the shield and then deal with the exhaust once I have the engine in. It was 10:30 and I couldn't feel my fingers anymore, so I decided to call it a night. (I never did get that shop heater I talked about... |
| Author: | wvenable [ Wed Feb 29, 2012 6:05 pm ] |
Don't sell that hood ya pinhead! You would be reducing yer options. Looks dang good from what I can see, A little white wid some blue flames and you would be a regular flamer! |
| Author: | Rob Simmons [ Wed Feb 29, 2012 6:30 pm ] |
Sellin' it DOES give me options! To buy other stuff I don't need! Duh! What's the difference between a regular flamer and an irregular flamer...? Wait! PLEASE don't answer that! |
| Author: | Rick Covalt [ Fri Mar 02, 2012 6:07 pm ] |
| Post subject: | Rib |
That rib right under your manifold stud is what was holding out my gasket and making a nice vacuum leak. Grind a little off if you want! Rick |
| Author: | Rob Simmons [ Sat Mar 03, 2012 3:06 am ] |
| Post subject: | Re: Rib |
Quote: That rib right under your manifold stud is what was holding out my gasket and making a nice vacuum leak. Grind a little off if you want!
Rick |
| Author: | Rob Simmons [ Thu Mar 08, 2012 8:23 am ] |
I ground down those two ribs on the side of the block that Rick pointed out and got the motor plate installed on the engine. I also started to install the scatter shield and new trans fluid cooler in the Challenger. I had to switch from the electric drill to my smaller air drill to drill the mounting holes in the frame. It was late and I didn't want to irritate the neighbors with the loud air compressor, so I called it an early night. All in all a fairly productive night at the garage. |
| Author: | Rug_Trucker [ Fri Mar 09, 2012 1:00 am ] |
I envy you! |
| Author: | Dart270 [ Fri Mar 09, 2012 5:25 am ] |
I am impressed, Rob. Progress. I'll believe all this stuff when I see a drag pass, tho... Lou |
| Author: | Rob Simmons [ Fri Mar 09, 2012 6:31 am ] |
Quote: I envy you!
I don't get the time often, so it's nice when things go smoothly.You're welcome to swing by and "play cars" with me anytime! Are you still planning to come up this way in early June for the bee handler's get together? Quote: I am impressed, Rob. Progress. I'll believe all this stuff when I see a drag pass, tho...
Nothing to really be impressed about, but at least it IS some progress. I'm still just a "Smoke Blowin' Poser" at this point though. Lou The weather looks good for the weekend,... we have no swim meet,..., local tracks are open,... and the Duster is ready to try out,... something's gonna come up or go wrong! |
| Author: | Rick Covalt [ Sat Mar 10, 2012 4:25 am ] |
| Post subject: | Cool |
Progress looks good. Racin in March ? I guess that means you've earned the shirt!! Congrats. Rick |
| Author: | Rug_Trucker [ Sat Mar 10, 2012 8:15 am ] |
Rob I have no idea if I am going up to the bee thing. Right now work is so weird. |
| Author: | Rob Simmons [ Mon Mar 19, 2012 11:47 am ] |
| Post subject: | Re: Cool |
Quote: Progress looks good. Racin in March ? I guess that means you've earned the shirt!! Congrats.
I thought there were more responses to this from Lou... Rick Quote: Rob I have no idea if I am going up to the bee thing. Right now work is so weird.
Just let me know if/when you'll be in the area and hopefully we can meet up someplace. I'll do the same if I'm in yer neck o' the woods. |
| Page 5 of 61 | All times are UTC-07:00 |
