| Guzzi car pics. https://slantsix.org/forum/viewtopic.php?t=47421 |
Page 5 of 5 |
| Author: | wvenable [ Sat Feb 11, 2012 5:23 pm ] |
I notice that the brake pedal is still intact. |
| Author: | Old6rodder [ Sat Feb 11, 2012 5:31 pm ] |
Quote: Mark, you are slacking! That wing nut has plenty of room in it to drill 2 holes through it.
Rick Quote: Found some more weight savings !!!!
![]() Guzzi Mark. |
| Author: | Rick Covalt [ Sat Feb 11, 2012 5:36 pm ] |
| Post subject: | You are sick |
You really are a sick puppy! Rick |
| Author: | madmax/6 [ Sat Feb 11, 2012 5:46 pm ] |
Look at the pedal close,the pad has been made smaller and there are holes on the arm.When I put that air cleaner on with the cold air ducts I picked up just over a 10th in the 1/8th from one week to the next,no other changes.Yea,,I am kinda a wing nut.Guzzi Mark |
| Author: | Dart270 [ Sun Feb 12, 2012 2:08 am ] |
Artful and functional!! Lou |
| Author: | Rick Covalt [ Sun Feb 12, 2012 6:06 am ] |
| Post subject: | Hole |
Center punch that carb stud and drill a hole straight down through it. Rick |
| Author: | terrylittlejohn [ Sun Feb 12, 2012 6:16 am ] |
i love the look and the theme of your car. |
| Author: | CNC-Dude [ Fri Feb 24, 2012 12:02 am ] |
Should have gotten some carbon fiber nitrous bottles, there much lighter than the aluminum ones. |
| Author: | 805moparkid [ Tue Feb 26, 2013 9:56 pm ] |
Quote: Should have gotten some carbon fiber nitrous bottles, there much lighter than the aluminum ones.
i told him about the mono leaf fiber glass springs to...
| Author: | NCDemon1971 [ Fri Jun 28, 2013 6:40 pm ] |
Mark, you are something else. We share very similar ideas on saving weight. How thick was the aluminum used on the body panels? I seriously thought about doing this because I have some rusted panels on the car and figure aluminum will be the solution. Patching the panels and adding steel/body filler will add weight, which I do not want. Keep up the awesome work. |
| Author: | slantzilla [ Fri Jun 28, 2013 8:33 pm ] |
Is Mark fixing the car? |
| Author: | Fopar [ Fri Jun 28, 2013 8:42 pm ] |
Yes, he is really nuts. Am I right Mark? Richard |
| Page 5 of 5 | All times are UTC-07:00 |
