It is currently Mon Nov 23, 2026 6:39 pm
Post new topic  Reply to topic  [ 70 posts ]  Go to page Previous 1 2 3 4 5
 Post subject: Good point, Bruce...
PostPosted: Wed Jun 25, 2003 11:49 pm
I'll think about that...currently my super six intake has the carb stove hooked up, but the thermactor isn't hooked to a vacuum source so the flap never is opened for warm air, it did ok during the winter (a bit finicky on those really cold mornings...).
When I'm working, I always have a highway commute, preceeded by 3 stop lights...so as long as it gets to the highway, I let it warm up at 65mph for 15-60 minutes.... :wink:
Thanks man,
PostPosted: Thu Jun 26, 2003 12:45 pm
Some carb heat is necessary for proper function on the street. With the HP you could used Cliffords water heated adapter. If you follow the various inline forums, you will notice, that just about everybody says heating the carb improves their daily driving.
On my supersix setup, I removed the flapper valve in the exhaust manifold and I am using the original '65 air cleaner. Even after complete warmup, and the intake is at engine temperature, the base of the carb is cool to the touch. It takes a long time for the carb to warm up and I can still experience carb icing, even in 70* weather. This is not unique to my Dart, the same thing happens to the 360 in my truck.
Half my carburation problems, I believe, stem from this. It is only after extended driving, an hour or more, that that my car starts to settle down and the flat spots on acceleration go away.
PostPosted: Tue Jul 01, 2003 10:22 am
I got an old Mopar Performance Six ylinder engine performance manual and found some info in the back about the four barrel packages recommended by the factory, including the Hyper pak! Here it is:
Note the air dam recommend for the floor of the intake. I noticed that the Clifford hyper-pak seems to have tiny air dams in front of runners 1&2 and 5&6. Was that part of the original design? Is this a design improvement over original? Doc?
Next are what the fctory recommend for regular four barrel and super six intakes. Nothing too exciting here, but I thought i would includ eit for the heck of it.
I also found the specs for the hyper-pak cam: 276-268-44 with a
.430 lift. Thats pretty beefy compared to the 71-up cam which was 244-244-26 with a .406 lift intake and .414 exhaust.
I have been trying to figure out the valve event timing on that h-pack cam.
Do you assume that the intake valve begins to open immediately following TDC on the exhaust stroke? So in relation to the crank (divide the advertised duration numbers by two correct?) the intake valve is open from 0-188 degrees, the exhaust valve is open 166-350 degrees? That can't be right since that leaves ten degrees at the top of the exhaust stroke with no valves open. I must not be understanding how to do this. HELP!
Reed
PostPosted: Tue Jul 01, 2003 10:49 am
Part of looking at the profile is see what lobe separation angle the cam was ground at...
Doc might have more insight about these things, although cam technology/design, etc... have moved forward a bit since that bump stick has come out...
"Don't bug me, I got a can of WD and heading to tear down a Holley....."
PostPosted: Tue Jul 01, 2003 11:11 am
Wouldn't the 44 degree overlap tell you the lobe separation angle?
PostPosted: Tue Jul 01, 2003 11:25 pm
The 44 degree overlap tells us that the intake opens "about" 22 degrees before TDC and the exhaust closes about 22 degrees after TDC.
I say about because the factory H. Pak cam is a dual pattern design so the events will be shifted a little to the intake side, much like advancing the cam would do.
Wow, this is not what I did to get the distribution working on this manifold.
There should be small dams in front of runners 3 & 4 ( the middle two) and larger dams in front of 1 & 6, these should go up the side walls some.
I found that runners 2 & 5 were the lean cylinders and the outer ends (1 & 6) were rich. I put dams in to direct mixture into runners 2 & 5.
The factory put a large dam in front of 3 & 4 to push mixture out to 2 & 5.
 Post subject: My dams...
PostPosted: Wed Jul 02, 2003 12:38 am
The dams in mine are on 1,3,4, and 6. smooth flooring from plenum to 2 and 5....
I'm not taking any dam pictures to prove it either.... :lol:
Any thoughts doc on my other posting about initial jets on a Holley for this install, I'm about ready to rebuild one or two, and depending on the schedule, I might be ready for some install by next week....
thanks Doc and Reed,
PostPosted: Wed Jul 02, 2003 2:07 pm
:oops: :oops: WHOOPS! I stand corrected. I just double checked my intake floor and it is just as DI said. I need to quite working form memory and verify these things before I open my mouth... :oops: :oops:
Thanks for the tip about the cam profile Doc! Now I can play around with it on my Desktop Dyno.
Reed
PostPosted: Wed Jul 02, 2003 4:03 pm
Good news on the floor dams, sounds like Clifford left the dams I put in there, this is good news based on the countless hours of mixture distribution testing and adjusting I did.
Just to let everyone know, even with the dams, #2 & #5 are still the lean cylinders, I find #2 to be the leanest on my sideways mounted Holley 600. #6 is the richest.
Based on this, I currently run a #65 jet in the forward primary and a #62 in the rear. The secondary has a plate that I have never touched. (no jets)
I would say to start with #62 jets and work from there. (read the plugs)
I bet the carb will want bigger squirter nozzels but again, give it a try to see if the combo will take a "stomp to the floor" from idle without a bog. (not likely)
In general, don't spend a bunch of time guessing on what jetting a carb should take. It is better to get the set-up running and then figure-out what the engine needs to runs the best.
PostPosted: Wed Jul 02, 2003 4:58 pm
Thanks Doc,
I have 1-2300, 1-4175, 1-4150, and 2-4160's open and receptive at the moment. I just wanted to get some 'baseline' wrather than dumping one off of my grandfathers's 383 on there and just hosing down the cylinder walls.
think I'll rebuild the 600cfm vac sec. carb I have, keep the '64' jets I have, get a 10.5 power valve (I got out the vacuum gauge today, but need some hose to see what my engine is like with the super six on it as a 'benchmark'). I'll keep the orange 466 cam and the stock '25' shooter...if it needs more shot I now have a pink cam and a '31' shooter to swap in...
My secondary plate is a '6' .070 main and .026 idle, which I think I'll keep to start (have a plate up from that and one down from that...)
will keep you posted as events/questions arise...
thanks!!!
"HyperPak Maniac"
