| Wiseco Big Bore pistons ANOTHER RUN!! https://slantsix.org/forum/viewtopic.php?t=68441 |
Page 5 of 7 |
| Author: | Greg Ondayko [ Thu Apr 30, 2026 11:45 am ] |
| Post subject: | Re: Wiseco Big Bore pistons ANOTHER RUN!! |
I can go for a set 3.504" or a set of 3.484". Whatever is best to complete the buy. Greg |
| Author: | Dart270 [ Thu Apr 30, 2026 2:36 pm ] |
I'm in for a 3.485" set, assuming that will help complete the buy. Thanks, Rob! Lou |
| Author: | Rob Simmons [ Sat May 02, 2026 6:14 am ] |
This is the current list of people wanting these pistons. I don’t know if this will be enough to get them to make a run or not. I’ll report back next week. Pro-Tru Chrysler 225 Slant 6 Compression height - 1.625 Wrist pin - .901 PT112H84 - $650 per kit PT112H104 - $650 per kit Rings XX style ring 1.0 x 1.2 x 2.8mm; Gas nitride top ring; Napier scraper 2nd; Flex-vent style oil set Roll Call: Rick Covalt - 3.504” x 1 Greg Ondayko - 3.504” x 1 Wayne Venable - 3.485” x 1 Lou Madsen - 3.485” x 1 IdahoCarson (FABO) - 3.504” x 1 Matt - 3.504" x 1 CJ - ??? I ordered a set of the cast crank rods to get us to the minimum required. I’m not in a position to do that for a set of pistons that will also set on the shelf until my estate sale… Hopefully Adam will be able to make a run with just 5-7 sets. More to follow. |
| Author: | Rick Covalt [ Sat May 02, 2026 8:03 am ] |
Thanks Rob! If it doesn't work out I'm fine with that too. Mine will set on the shelf for a while too! |
| Author: | Rob Simmons [ Tue May 05, 2026 11:16 am ] |
| Post subject: | Wiseco Big Bore pistons GO TIME!! |
Okay Fellers! I just confirmed we are a go for this group buy. Same cast of characters, so you all have my PayPal and Venmo to send the deposits. ($325 for half, or if you prefer round numbers, $350 All deposits received (except Cookie, ‘cuz he just does the old “snail mail” thing… BONUS!!! Adam just dropped the price to just $600 per set!! Roll Call: Rick Covalt - 3.504” x 1 Greg Ondayko - 3.504” x 1 Wayne Venable - 3.485” x 1 Lou Madsen - 3.485” x 1 IdahoCarson (FABO) - 3.504” x 1 Matt Deemer - 3.504" x 1 |
| Author: | wvenable [ Tue May 05, 2026 1:30 pm ] |
https://www.youtube.com/watch?v=jjaqrPpdQYc |
| Author: | Rick Covalt [ Tue May 05, 2026 5:07 pm ] |
Money sent! Thanks Rob. You can hold mine till Clay City if that works for you. |
| Author: | Greg Ondayko [ Wed May 06, 2026 5:49 am ] |
Planning on Clay City at this time, so bring my Rods and Pistons there if possible. If that falls through we can work out shipping. Thanks, Greg |
| Author: | Dart270 [ Wed May 06, 2026 9:50 am ] |
Paypal sent! Thanks again. Lou |
| Author: | Rob Simmons [ Thu May 07, 2026 7:56 am ] |
See above for update on deposits received AND a price drop!! |
| Author: | Rick Covalt [ Thu May 07, 2026 8:54 am ] |
Thanks Rob! Good news! |
| Author: | Rob Simmons [ Fri May 08, 2026 6:05 am ] |
Update for folks like Lou who originally wanted the smaller size. Reply from Adam below. BLUF: The smaller 3.425 and 3.445 are shelf stock items, but we can order them through this group buy if preferred. Quote: PT112H84 is 88.50 bore size = 3.484
PT112H104 is 89mm bore size = 3.503 PTS536 Series , 3.425" & 3.445" yes these are a current shelf stock. The larger ones I reactivated would be considered a custom since they were discontinued. You can add the other part #’s to you order if you like. |
| Author: | Rob Simmons [ Wed May 13, 2026 10:54 am ] |
This is the current list of people getting these pistons. Updated as of 13 May. Pro-Tru Chrysler 225 Slant 6 Compression height - 1.625 Wrist pin - .901 PT112H84 - $600per kit PT112H104 - $600 per kit Rings XX style ring 1.0 x 1.2 x 2.8mm; Gas nitride top ring; Napier scraper 2nd; Flex-vent style oil set Roll Call: Rick Covalt - 3.504” x 1 - $350 deposit Greg Ondayko - 3.504” x 1 - $325 deposit Wayne Venable - 3.485” x 1 - $350 deposit Lou Madsen - 3.485” x 1 - $325 deposit IdahoCarson (FABO) - 3.504” x 1 - $350 deposit Matt Deemer - 3.504" x 1 - $325 deposit Rob Simmons - 3.485” x 1 - $350 deposit Mandi Gravatt - 3.485” x 1 - $300 deposit Turn around time is estimated at 8-10 weeks. |
| Author: | joesnow [ Tue May 19, 2026 7:16 pm ] |
Is it too late to get in on a set? |
| Author: | Rob Simmons [ Wed May 20, 2026 9:46 am ] |
I have already got this batch in the works, but you can reach out to Adam Thornton @ Wiseco Pistons to see if you can still squeeze in a set.(440) 497-3137 |
| Page 5 of 7 | All times are UTC-07:00 |
