| Rob's 1981 Dodge Challenger https://slantsix.org/forum/viewtopic.php?t=46322 |
Page 44 of 61 |
| Author: | Rob Simmons [ Fri Oct 01, 2021 8:13 pm ] |
| Post subject: | Re: Rob's 1981 Dodge Challenger |
Adam came over this evening and re-mounted the gas pedal for me. WAAAAY better! I think I’ll actually be able to make a pass at full throttle without becoming a contortionist and getting leg cramps now! I should have been working on the Challenger, but was out back getting something else done… Fun times!! Thanks Adam!! |
| Author: | Exner Geek [ Sat Oct 02, 2021 6:05 am ] |
I count at least 8 or 10 rockers, how did you do that? When I bought my first set from Rocker Arm Specialists I told them they couldn't be purple. Make Norm proud! |
| Author: | Rob Simmons [ Sat Oct 02, 2021 6:19 am ] |
My main goal is to show Norm his car went to a good home by re-setting his record. What color were your RAS rocker arms, Seymour? I’ve only seen blue and purple. There are 12. The angle of the photo is misleading. |
| Author: | Rob Simmons [ Sun Oct 03, 2021 3:18 pm ] |
I got the initial cold valve lash set and even put water in it…. I guess I’m getting close. I’m about to dive into the hood scoop surgery… Wish me luck! |
| Author: | Rob Simmons [ Sun Oct 03, 2021 3:52 pm ] | ||
| Post subject: | Re: Rob's 1981 Dodge Challenger | ||
No turning back now!
| Author: | Rob Simmons [ Sun Oct 03, 2021 5:29 pm ] | ||
Kinda hoakie, but I’ll make it work for now…
| Author: | terrylittlejohn [ Mon Oct 04, 2021 5:44 pm ] |
last run of the year is always the best! |
| Author: | Rick Covalt [ Mon Oct 04, 2021 6:24 pm ] |
Quote: Kinda hoakie, but I’ll make it work for now…
A little Camo Gorilla Tape around the edges and you will be golden!! |
| Author: | Rob Simmons [ Mon Oct 04, 2021 8:37 pm ] | |||
| Post subject: | Re: Rob's 1981 Dodge Challenger | |||
I spent the evening fiddling with the hood scoop. I’m more satisfied now. It ain’t great, but it’ll do. I’ll spray bomb some white on it. It’ll be a 50/50 job fer sher.
| Author: | Badvert65 [ Tue Oct 05, 2021 4:45 am ] |
Rob, do you even need a scoop? Is it for clearance or air for the engine? |
| Author: | Rob Simmons [ Tue Oct 05, 2021 5:57 am ] |
It's a little of both, Matt. The top of the Flying Toilet sits just about 1" under where the bottom of the hood would be without a scoop. The original Six Pak scoop was basically just open, allowing air under and through without being sealed at all. You could see the hood trying to lift as you went down the track. I am hoping this design will offer better aerodynamics and slow the air down to feed the engine better. |
| Author: | Rob Simmons [ Wed Oct 06, 2021 9:05 pm ] | |||
Close enough.
| Author: | and739 [ Thu Oct 07, 2021 6:15 am ] |
I think the shape of that hood goes well with the Challenger's lines. Excellent choice! Are more flames going back on? |
| Author: | Rob Simmons [ Thu Oct 07, 2021 8:21 am ] |
I’m not sure about more flames. If Norm wants me to I sure will! |
| Page 44 of 61 | All times are UTC-07:00 |
