| GodsRods Duster II https://slantsix.org/forum/viewtopic.php?t=39102 |
Page 45 of 47 |
| Author: | Rob Simmons [ Sat Oct 06, 2018 7:07 pm ] |
| Post subject: | Re: GodsRods Duster II |
The Duster finally let me down. First round of eliminations against Ryan Covalt. I staged and started to bring the RPMs up for the launch and it died. Greg Ondayko pulled the front float bowl and found some gunk. Better, but still not right. I pulled the carb apart again sitting on the tailgate in the motel parking lot and blew carb cleaner through all of the passages. We will see if that helped enough. On a high note: Angie won her first round to take the lead as Rookie of the Year!! Rick Covalt let her drive his truck. She had a blast and wants to start racing now!! |
| Author: | Rob Simmons [ Sun Oct 07, 2018 4:08 pm ] |
Good day of racing today. Carb is good/better. It doesn’t idle as well since I messed with the bleeder screws, etc. Still good enough for Runner Up and a break out. Still very consistent. Just needs a more consistent driver. Angie may want to try her hand at the Duster next. I decided to save the Nitrous record for Knoxville. Hopefully that won’t come back to bite me. Jack Everhardt Jr. wants to take some weight out of his car and go for the same B/Nitrous record. If I set it this weekend he likely wouldn’t be able to re-set it, so I told him I would wait. It will make Knoxville that much more exciting. |
| Author: | Challenger [ Mon Oct 08, 2018 1:39 pm ] |
I hope to be in Knoxville also and may go for that record. Love that juice. |
| Author: | Rob Simmons [ Mon Oct 08, 2018 5:38 pm ] |
You’d better get it weighed then. Raccoon Valley is gonna smell like nitrous for a week! |
| Author: | slantzilla [ Thu Oct 11, 2018 10:52 am ] |
Cranking up the right side torsion bar a little will balance your weights out better. |
| Author: | Rob Simmons [ Thu Oct 11, 2018 11:01 am ] |
I was thinking about that when I saw those corner weights. Thanks Dennis! |
| Author: | slantzilla [ Mon Oct 15, 2018 2:35 pm ] |
Cool stuff! |
| Author: | emsvitil [ Tue Oct 16, 2018 12:57 am ] |
That's photoshopped. If he fixes his corner weights it will probably not do it. |
| Author: | wvenable [ Tue Oct 16, 2018 5:20 am ] |
Got some air - nicely done Mater! |
| Author: | Rob Simmons [ Sat Oct 20, 2018 7:41 am ] |
I’ve still got 46 pounds I can add and stay in B class... Put that in the back and twist the bars even further in the wrong direction... That oughta do it! |
| Author: | Rob Simmons [ Wed Oct 24, 2018 6:54 am ] |
I put the nitrous fuel line back in along with colder Autolite plugs gapped at .025 for this weekend. New drool tube O rings as well. We will see... |
| Author: | Rick Covalt [ Wed Oct 24, 2018 9:42 am ] |
You may need wheelie bars!! |
| Author: | Rob Simmons [ Thu Nov 15, 2018 10:11 am ] |
I was going to fire up the Duster one last time before winterizing it so I could be like Dennis and run a compression test on it.... It froze the other night before I got around to it... No damage that I can tell, but the water and fuel are drained now. We had a decent ice storm last night that downed a lot of trees. Several large branches fell near and on the Dart and Valiant. I didn't see any major damage while I was moving the frozen branches to get to work this morning. The ice was still coming down, so I didn't dawdle... Have I mentioned that I miss living in Arizona...? |
| Page 45 of 47 | All times are UTC-07:00 |
