1972 Dodge Colt
Page 47 of 81
Author:  Dart270 [ Sun Oct 22, 2023 5:34 pm ]
Man, hard to catch a break! Keep at it... I wonder if the gas pedal/linkage is trying to push the carb throttles further than WOT and that is loosening them or forcing them to rotate on the shaft?
Author:  slantzilla [ Sun Oct 22, 2023 5:48 pm ]
Sorry to hear that Stan.
Author:  Will [ Mon Oct 23, 2023 4:36 am ]
Sucks, keep plucking away at it.
Will
Author:  Rick Covalt [ Mon Oct 23, 2023 9:10 am ]
I would check that also. My Webers had a stop cast into the body. Mine were not opening far enough so I adjusted that. :D :D
Keep at it Stan! We are rootin for you!
Author:  hyper_pak [ Fri Oct 27, 2023 11:39 am ]
Found this on another tread.
And to think, I was told I needed to turn 7000.
Author:  slantzilla [ Fri Oct 27, 2023 10:48 pm ]
Problem is you cannot even turn 4300.........
Actually, after I put the 4.86 gears in we turned it 6700 and it kept pulling.
I know you're too proud to do it, but let me send you my Nyutten 650 Holley to try. Leave the Webbers until you have actually gotten some good runs on the car, then start screwing with the Webbers. :mrgreen:
Author:  hyper_pak [ Sat Oct 28, 2023 12:19 pm ]
Actually they are spelled "Weber".
Not too proud, look at the abuse I am taking.
If I was proud I would crawl in a hole in a fetal position!
Yea a couple of issue with the Webers, but I do like them.
I have a new lever on order from Speedway.
I have a 650 DP sitting on another intake ready to go.
Author:  slantzilla [ Sat Oct 28, 2023 8:26 pm ]
Trust me Stan, nobody wants to see that car fly more than me.
It's just too much fun kicking you when you're down. :mrgreen:
Author:  Dart270 [ Sun Oct 29, 2023 3:59 am ]
Another emphatic vote for swapping to a known good 4bbl, just to make sure the webers are not your problem... This could save you a ton of work and time and heartache, in the case that the webers are somehow still not functioning properly
Author:  hyper_pak [ Sun Oct 29, 2023 7:38 am ]
I hear you both.
I want to see what the trans does before I pull the intake.
Just as a reminder, it's starting to cool off here in Texas so I assume the rest of the US is as well.
Please DRAIN your water from your race cars or install some anti-freeze.
If you are cold they are as well.
Don't need anymore cracked cast iron!
Author:  slantzilla [ Sun Oct 29, 2023 8:54 am ]
:oops:
Author:  hyper_pak [ Mon Oct 30, 2023 8:38 am ]
Oh not you zilla, I was talking about other folks.
Author:  Greg Ondayko [ Mon Oct 30, 2023 11:42 am ]
I suppose this is all part of the teething process in sorting a car.
Ruster Ran 19.20 the first time out. Then after an engine build, it was solidly into the 13's, then the 12's then the 11's.. Simplify then add lightness. :D
I still have all kinds of problems with the megasquirt on the ignition, but when it works it works well, and I have only myself to blame.
Keep focused, you'll get there. I would also throw that other intake on and see if there is and induction problem or not.
Author:  slantzilla [ Mon Oct 30, 2023 2:25 pm ]
I was talking to Patrick Saturday. That motor always used water and snotted up under the valve cover really bad. I never got any water in the pan. It's possible the head was already cracked anyway.
We're going to try and fix it ourselves. What have we got to lose? :mrgreen:
Author:  hyper_pak [ Mon Oct 30, 2023 2:50 pm ]
Zilla, Nuthing!
Page 47 of 81 All times are UTC-07:00
