| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 48 of 128 |
| Author: | olafla [ Fri Nov 08, 2013 6:09 pm ] |
I would have contacted ARP, and sent them all photos, including some more detailed photos of the broken rod bolt. In my opinion, the bolt may be hardened incorrect, the softer bolt core should not have that oval pattern when over stretched. Olaf |
| Author: | CNC-Dude [ Fri Nov 08, 2013 9:00 pm ] |
Rick, in the bottom picture, is the section on the rt hand side of the bolt shiny or just oily. If its shiny, this indicates where the failure began, likely a flaw in the bolt. The matching upper section of the bolt and this section were rubbing and chaffing against each other. The center and left section are where the bolt had its sudden failure and broke apart with basically only 2/3 of the shank diameter left to endure the stresses it was subjected too. Given the power output and the RPM the rod bolts saw in your engine, I don't see how that was the cause, it was more that likely a flaw in the bolt that was to blame. |
| Author: | Rick Covalt [ Sat Nov 09, 2013 6:00 am ] |
Here are 2 more pictures of the bolt. I washed it off with brake cleaner. Sides are definitely more shiny, center more rough. ![]()
| Author: | Romeo Furio [ Sat Nov 09, 2013 6:23 am ] |
I'd be callin' ARP and sendin' the photos. with a little luck you may get something out of them. |
| Author: | Rick Covalt [ Sat Nov 09, 2013 9:26 am ] |
I will be anxious to get the pan off and find the other half of the bolt. I'm just hoping that some of the pieces did not leave the side of the pan and are lost forever. Rick |
| Author: | CNC-Dude [ Sat Nov 09, 2013 1:07 pm ] |
Yes, these newer pics confirm my earlier diagnosis. Cleaning the bolt and a little better angle helped. |
| Author: | USAJon [ Sat Nov 09, 2013 3:04 pm ] |
| Post subject: | found this interesting rick |
http://www.cp-carrillo.com/Tech/RodTech ... fault.aspx |
| Author: | Will [ Sun Nov 10, 2013 5:53 am ] |
Did they come from a relible vendor? There has been a problem with fake ARP blots. Lube on the back of an older pack. The instructions were with the lube. Will
| Author: | USAJon [ Sun Nov 10, 2013 9:03 am ] |
Quote: Did they come from a relible vendor? There has been a problem with fake ARP blots. Lube on the back of an older pack. The instructions were with the lube.
see hereWill ![]() http://www.hotrod.com/feature_stories/1 ... to_28.html |
| Author: | slantzilla [ Sun Nov 10, 2013 9:39 am ] |
Rick, you may never pinpoint the real source of the failure, but one thing you have learned, education is expensive no matter what school ya get it from. |
| Author: | Rick Covalt [ Sun Nov 10, 2013 12:29 pm ] |
I got mine off the internet from Maddog racing. I would guess they are a reliable source. As for the lube and instructions, I don't know. If they were on the back I never saw or felt them.Quote: you may never pinpoint the real source of the failure, but one thing you have learned, education is expensive no matter what school ya get it from.
Yep, that is what I figured!
| Author: | Romeo Furio [ Sun Nov 10, 2013 2:09 pm ] |
I think ARP would want to know,and evaluate the items. Even if they don't compensate. You never know unless you try. |
| Page 48 of 128 | All times are UTC-07:00 |
