It is currently Tue May 26, 2026 1:53 pm
Post new topic  Reply to topic  [ 79 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Thu Dec 30, 2010 9:51 am
The pod is kicking in giving you more advance at 850 rpm. Dial it out and the idle will come down. Use ported vacuum for the pod.
PostPosted: Thu Dec 30, 2010 9:59 am
ok. i'll give it a try.
it did do this same thing with the old non adjustable pod too.
PostPosted: Thu Dec 30, 2010 11:34 am
Gato,
Have you read the Doc' scanned distributor adjustment .jpgs under Engine FAQ? The 4th page tells you how to adjust it.
I run my 11R pod VC-208 3 turns out. That way it will not kick in too quick. It is the fine tuning that gets your re-curve to work the best.
Hope that helps! :) :) :)
PostPosted: Thu Dec 30, 2010 1:23 pm
i even have a printed copy on my workbench. i'll double check it in the next day or 2..
maybe that'll help the "stumble"..
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
