| distributor recurve https://slantsix.org/forum/viewtopic.php?t=42635 |
Page 6 of 6 |
| Author: | Aggressive Ted [ Thu Dec 30, 2010 9:51 am ] |
The pod is kicking in giving you more advance at 850 rpm. Dial it out and the idle will come down. Use ported vacuum for the pod. |
| Author: | gato [ Thu Dec 30, 2010 9:59 am ] |
ok. i'll give it a try. it did do this same thing with the old non adjustable pod too. |
| Author: | Aggressive Ted [ Thu Dec 30, 2010 11:34 am ] |
Gato, Have you read the Doc' scanned distributor adjustment .jpgs under Engine FAQ? The 4th page tells you how to adjust it. I run my 11R pod VC-208 3 turns out. That way it will not kick in too quick. It is the fine tuning that gets your re-curve to work the best. Hope that helps! |
| Author: | gato [ Thu Dec 30, 2010 1:23 pm ] |
i even have a printed copy on my workbench. i'll double check it in the next day or 2.. maybe that'll help the "stumble".. |
| Page 6 of 6 | All times are UTC-07:00 |
