DrGonzo's 1963 Dart 225
https://slantsix.org/forum/viewtopic.php?t=44333
Page 6 of 7
Author:  Badvert65 [ Fri Mar 27, 2020 4:55 pm ]
Post subject:  Re: DrGonzo's 1963 Dart 225
Image[/quote]
Is that a good place for the return spring to be mounted? Looks like engine torque would try to close the throttle on you.
jus sayin....
Author:  drgonzo [ Fri Mar 27, 2020 7:05 pm ]
It is NOT a good place to mount it and it is not permanent. Good eye!
Author:  Rick Covalt [ Sat Mar 28, 2020 8:40 am ]
I just thought the motor mount was torn and that was holding the engine in place! :D :D
Author:  Badvert65 [ Sat Mar 28, 2020 8:43 am ]
Poor man's Rev Limiter.......
Author:  drgonzo [ Sat Mar 28, 2020 9:36 am ]
I can't believe you guys haven't already seen the combination throttle return spring/torque strap. It's been around. :mrgreen:
Author:  Badvert65 [ Sat Mar 28, 2020 10:32 am ]
I have been a little out of touch with the TRUE racers for a while now.
Keep all these tips and tricks coming.
Author:  drgonzo [ Sat Mar 28, 2020 12:27 pm ]
I have abandoned experimental tech for the time being.
Author:  Badvert65 [ Sat Mar 28, 2020 1:29 pm ]
You went 'conventional'....
Is that allowed?
Author:  drgonzo [ Sat Mar 28, 2020 2:36 pm ]
Is that allowed?
The fact that you are here says the same for you.
Author:  Badvert65 [ Sat Mar 28, 2020 4:17 pm ]
Point taken.
Author:  Greg Ondayko [ Sat Mar 28, 2020 9:42 pm ]
Is that a good place for the return spring to be mounted? .
Mine has been mounted in a similar fashion for many years on the hyperpack dart... never had any problems.
Author:  drgonzo [ Sun Mar 29, 2020 8:07 am ]
Really that set up didn't present any problems while driving and the reality of it is, throttle return springs are trying to close the throttle all the time.
Author:  sixinthehead [ Sun Mar 29, 2020 11:22 am ]
All the extra 'Bigfoot' adrenaline at WOT easily overcomes a little extra spring tension 8)
Author:  drgonzo [ Sun Mar 29, 2020 11:33 am ]
Joe knows :mrgreen:
Author:  drgonzo [ Sat May 23, 2020 4:46 pm ]
Going up to Paradise tomorrow and see if the changes I've made help or hurt. Maybe I will run into Finnegan, but I doubt it. :D
Page 6 of 7 All times are UTC-07:00
