| supercharged d150 https://slantsix.org/forum/viewtopic.php?t=55118 |
Page 6 of 7 |
| Author: | Dart270 [ Fri Sep 12, 2014 10:41 am ] |
Glad to hear the trip went well, except for the pump hiccup. Nice work. Lou |
| Author: | billdedman [ Sun Sep 28, 2014 8:41 pm ] |
Have you considered putting your truck on a chassis dyno or a drag strip to see how the successful set of modifications does in the performance arena? I'd be very interested to see some hard numbers with related boost information for that test. I have a lot of friends who are very interested in what you have accomplished here. Keep up the excellent work!!! Bill, in Conway, Arkansas |
| Author: | moparmatt441 [ Tue Sep 30, 2014 3:05 pm ] |
Ultimately I plan on getting some dyno runs, I am currently building a water/air intercooler that will sandwich between the bottom of blower and intake. |
| Author: | 65 dartman [ Tue Sep 30, 2014 3:33 pm ] |
I have an 87 short wheelbase with a slant in it. Would love to run an upgrade like you have done. Ever consider selling the adapters needed to make this work? |
| Author: | dartsport76 [ Tue Sep 30, 2014 3:45 pm ] |
Could you elaborate on the intercooler? I thought this couldn't be done with a draw through setup? |
| Author: | moparmatt441 [ Tue Sep 30, 2014 4:12 pm ] |
Quote: Could you elaborate on the intercooler? I thought this couldn't be done with a draw through setup?
I am using a heat exchanger from an 03 cobra terminator, as well as the pump. I will be using a custom heat exchanger just below the blower , I will build a storage tank and run engine ice in the system. It will work very similar to this.http://teaguecustommarine.com/em0011/su ... ooler.html |
| Author: | Serj22 [ Tue Sep 30, 2014 10:09 pm ] |
Would something like the maine 2bbl waterjacket manifold work for that? then you could make adapters for it im assuming? |
| Author: | moparmatt441 [ Sun Oct 12, 2014 1:58 pm ] |
decided to go even bigger, going to adapt a 112 supercharger onto this engine. |
| Author: | 65 dartman [ Sun Oct 12, 2014 2:55 pm ] |
PM on the way |
| Author: | Dodge 330 [ Thu Oct 30, 2014 5:43 pm ] |
I just happen to catch one of the videos on your truck and was blown away! Very impressive in deed. By chance will you be installing a header on the truck soon? Not sure I saw one from your latest pic's. |
| Author: | DadTruck [ Sat Nov 22, 2014 6:32 am ] |
W post on the progress.. |
| Author: | JayceLane [ Fri Oct 02, 2015 7:07 am ] |
Hi all the way from South Africa. Matt I hope your build is moving along nicely. You are one of the main reasons why I joined the forum, I have a GM M90 on its way to me from the States which should be getting to me next week. I am wanting to go for a draw through (Wet) system similar to yours and was wondering how your setup is still running. Also to hopefully confirm some aspects regarding running the M90 wet. Look forwarding hearing from you. Cheers |
| Page 6 of 7 | All times are UTC-07:00 |
