| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://slantsix.org/forum/viewtopic.php?t=60536 |
Page 6 of 40 |
| Author: | Greg Ondayko [ Mon Jan 28, 2019 1:51 pm ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
Quote: Will that induce a twist in the lower arm since it's so far off the centerline?
Possibly - not sure about that?? That's where the FFI Bar lands when mocked up. If I used their tabs it would have been similar. I was trying to get the end links for the bar pretty square in 90° opposing planes at ride height, as per the recommendation of mopar suspension sages I bet with the Lower Strut and Torsion Bar Mount in triangulation it will be okay. Greg |
| Author: | drgonzo [ Tue Jan 29, 2019 5:36 am ] |
Greg what kit and where did you purchase it to rebuild that steering knuckle? I need to get one for my '63. |
| Author: | Greg Ondayko [ Tue Jan 29, 2019 9:26 am ] |
Quote: Greg what kit and where did you purchase it to rebuild that steering knuckle? I need to get one for my '63.
Dr.Gonzo: Check Here: https://www.detroitmuscletechnologies.c ... n-related/\ they are also on ebay. The coupler and bolt / clamp in that photo is the original - I disassembled it, the gasket was trashed so I got a new one and clamp. Cleaned, blasted and painted it - re assembled it. I have to do it again as I did not align the Master splines correctly on the top of the shaft and the bottom of the coupler - its's 180° out now. Greg |
| Author: | drgonzo [ Tue Jan 29, 2019 10:16 am ] |
Thanks, Brad |
| Author: | Rob Simmons [ Thu Jan 31, 2019 5:44 am ] |
I can relate. I had to change the fuel tilter on Hamish II last night. It won't fit in the garage, so I had to do it outside in 7* snowy weather. I couldn't feel my fingers. |
| Author: | sixinthehead [ Mon Feb 04, 2019 6:21 am ] |
Lookin' good! I love the crusty drop stopper under that shiny new UCA How did the sway bar mounts on the K-frame come out? |
| Author: | Greg Ondayko [ Mon Feb 04, 2019 8:23 am ] |
Quote: Lookin' good!
Sway Bar Mounts are fine - I wont really know until I start Driving it but for now they are fine in theory!I love the crusty drop stopper under that shiny new UCA How did the sway bar mounts on the K-frame come out? Yes, those upper bump stops are toast. I don't plan on using them much, but they will get replaced - It's just not critical yet so I deferred the $20 to other parts of the project for now. The Lower ones are the originals and Looked great After I hit them with the sandblaster, so Back in they went.. They are the critical ones for the car's intended use. Greg |
| Author: | Badvert65 [ Mon Feb 04, 2019 1:36 pm ] |
What sort of front shocks are those. They have the oil reservoir on the top? |
| Author: | Greg Ondayko [ Mon Feb 04, 2019 2:12 pm ] |
Hi matt, Those are edelbrock shocks. I doubt they have oil in them although they might. Long since discontinued but revered by many. Look up edelbrock shocks discontinued for more info. Greg |
| Author: | sixinthehead [ Mon Feb 04, 2019 8:16 pm ] |
Just razzing you about the drop stop - I usually leave them off anyway. What does the frame mount look like? Just wondering if they are any different than what I am used to seeing. |
| Author: | Dart270 [ Tue Feb 05, 2019 4:02 am ] |
Edels definitely have oil in them. Nice to have more of the weight sprung. Great work, Greg. Lou |
| Author: | Greg Ondayko [ Tue Feb 05, 2019 8:20 am ] |
Quote: Edels definitely have oil in them.
Cool, I wasn't Sure as they felt like gas charged ones - It's one heck of an ab workout to get them compressed and into the suspension!Lou Greg |
| Page 6 of 40 | All times are UTC-07:00 |
