| Uncle Tony's Garage https://slantsix.org/forum/viewtopic.php?t=64038 |
Page 6 of 7 |
| Author: | slantzilla [ Tue Feb 02, 2021 7:39 pm ] |
| Post subject: | Re: Uncle Tony's Garage |
Mike used Comp religiously. He also designed his own lobes and had a contact at Comp who was a very successful 6 cylinder racer. I doubt if he is still there. I've had and still have some of the cams Mike had made. Most are not for the timid. Comp has changed hands a couple times in the last 10 or so years, and the last new owner isn't overly concerned with quality. Lucky for me I have enough cams to last the rest of my days. |
| Author: | slantzilla [ Tue Feb 02, 2021 7:47 pm ] |
For a 3500-6000+ powerband it is hard to beat an old Clifford 300M. Don't scrimp on converter and gears and it will definitely haul the mail. In all seriousness, the biggest reason a lot of cans won't perform is getting gun shy on the converter. You can experiment with lobes all you want, but with a crap head and tiny bore like we're stuck with there won't be much difference between a Chevy lobe and a Mopar one. |
| Author: | DadTruck [ Tue Feb 02, 2021 8:37 pm ] |
Dennis, I am with you on believing that the right converter will make a difference. But at least with cams, I can comprehend and make a relationship between: duration, lift, LSA and ICL and figure out what makes sense for the engine being built. With converters, if I have this right, you tell the manufacturer your engines peak torque and HP, vehicle weight, and maybe tire size and gear ratio and then the magic happens. There seems to be a lot more hodo vudu when it comes to getting the right torque converter. |
| Author: | Dart270 [ Wed Feb 03, 2021 4:50 am ] |
Agreed that most people are too shy about the converter. In my experience, Andre at Edge has built the closest to my specs (twice) and they hit my expectations. Lou |
| Author: | Badvert65 [ Wed Feb 03, 2021 5:53 am ] |
I am watching this with interest. I am curious to see the outcome of his slant six efforts. I am not quite on board with some of his ideas, but we shall see how it all gells in the results. |
| Author: | drgonzo [ Wed Feb 03, 2021 9:43 am ] |
I think it's interesting for sure. It appears to be a reasonably serious effort to build a relatively powerful slant six. Usually, outside of this board all I see is your basic rebuild with some off the shelf stuff from summit slung at it. This one is a low buck effort with a lot of work put into it. Let's see some ETs! |
| Author: | Rob Simmons [ Wed Feb 03, 2021 10:56 am ] |
Quote: Let's see some ETs!
Fer Sher!! Dennis put me in contact with the feller from the IHRA that wants to put a Slant 6 class together for a Mopar event in Missouri possibly around June. He told me that Uncle Tony was "all in" for it... So there's that... if anyone is interested... With UT's parts selection and focus on low range torque I wonder how it will effect his top end. It might kinda die off at the top end... I dunno. |
| Author: | Badvert65 [ Wed Feb 03, 2021 11:24 am ] |
You know, if nothing else, UTG may spark some interest in the Slant. |
| Author: | Rob Simmons [ Wed Feb 03, 2021 12:55 pm ] |
True Dat! |
| Author: | Rick Covalt [ Wed Feb 03, 2021 2:22 pm ] |
Quote: Andre at Edge has built the closest to my specs (twice) and they hit my expectations.
He hit mine dead on too. 4000 stall. Plus he was super to talk to on the phone. I didn't really know what I was asking other than I wanted to get into the 12's, and wanted it to be bulletproof if I hit it with a 300 shot of nitrous!!! |
| Author: | Greg Ondayko [ Wed Feb 03, 2021 3:22 pm ] |
Quote: You know, if nothing else, UTG may spark some interest in the Slant.
sparking interest and actually following through are different things. I have a sparked interest in tennis. don't think I am getting a racket or hitting the court ever. Greg |
| Author: | Charrlie_S [ Wed Feb 03, 2021 3:33 pm ] |
Quote: Quote: Andre at Edge has built the closest to my specs (twice) and they hit my expectations.
| Author: | slantzilla [ Wed Feb 03, 2021 5:46 pm ] |
Quote: Quote: Let's see some ETs!
Dennis put me in contact with the feller from the IHRA that wants to put a Slant 6 class together for a Mopar event in Missouri possibly around June. He told me that Uncle Tony was "all in" for it... So there's that... if anyone is interested. |
| Author: | Rob Simmons [ Thu Feb 04, 2021 7:32 am ] |
So many HRAs.... We're the SSHRA!! |
| Author: | drgonzo [ Thu Feb 04, 2021 8:15 am ] |
I just saw on YouTube that UT is looking for two 67-69 170s and only those specific years. Why would that be, crankshaft registry? Charlie will know. |
| Page 6 of 7 | All times are UTC-07:00 |
