| 1962 Valiant Station Wagon https://slantsix.org/forum/viewtopic.php?t=67103 |
Page 6 of 14 |
| Author: | Greg Ondayko [ Mon Jan 08, 2024 11:09 am ] |
| Post subject: | Re: 1962 Valiant Station Wagon |
Quote: Quote: I am not sure if I understand all of that from the crude side view
Good, I thought it was just me. After spending some thinking time on it I might understand. I think It's a 2D Drawing of multiple cuts/angles on the tube to both the radius and axis that is probably best portrayed in 3D... maybe. Greg |
| Author: | SlantSixDan [ Mon Jan 08, 2024 1:49 pm ] |
Quote: Quote: 45° down, then a horizontal slash cut starting at the outermost/uppermost point of the end of the spout, then a vertical cut chopping off about 3/4" of the outermost/uppermost part of the end of the spout. Very tidy and functional. Crude side view:
I am not sure if I understand all of that from the crude side view |
| Author: | Greg Ondayko [ Mon Jan 22, 2024 11:11 am ] |
| Post subject: | 1/22/24 |
1/22/24: Got some things accomplished.. Started off the work day by truing the backing plates that was on the used rear axle I bought - Some of the "Rub Blocks" were rubbed a bit too much with a large gouge in some areas... so I welded and ground on those areas a bit. ![]() ![]() ![]() After welding/grinding, one more trip to the blast cabinet - the repair was imperceivable. ![]() Short Block assembly time: ![]() ![]() ![]() The Crank and pistons were all assembled by the end of my session. I am picking a New cam and Head so this engine should run very well - The stock stuff will be in the queue for reworking someday! |
| Author: | Dart270 [ Tue Jan 23, 2024 5:15 am ] |
Very cool. I hope I can get my buttocks back in the shop before long... Lou |
| Author: | Andrew Shank [ Thu Feb 01, 2024 5:11 am ] |
It's looking good Greg! I like reading up on your progress. Keep up the good work, its inspiring. I told Rick the other night when we were done working I didn't take any pictures of what we got done... I'll try to do better next time haha. |
| Author: | Greg Ondayko [ Thu Feb 01, 2024 7:32 am ] |
Quote: It's looking good Greg! I like reading up on your progress. Keep up the good work, its inspiring. I told Rick the other night when we were done working I didn't take any pictures of what we got done... I'll try to do better next time haha.
Thanks, Andrew! You always have access to a professional photo rig in your pocket. You just got to get it out and use it. |
| Author: | Greg Ondayko [ Tue Feb 06, 2024 9:19 am ] |
| Post subject: | Ding! |
Ding! The gaskets are ready! - Come on down and get' em whenever is convenient for you.
| Author: | SlantSixDan [ Tue Feb 06, 2024 9:36 am ] |
Hey, those gaskets are really nice! |
| Author: | Greg Ondayko [ Tue Feb 06, 2024 10:02 am ] |
Quote: Hey, those gaskets are really nice!
Thanks, Dan, They are not the exact correct material, on short notice, But I own all of the IP to make these out of any material I want as they are digital files. There seems to be a lot less support in the aftermarket for the '60-'62 Models that are "A Bodies" as they do not interchange with the Muscle cars as often. So what DMT does not make, I will make. Greg |
| Page 6 of 14 | All times are UTC-07:00 |
