| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 52 of 128 |
| Author: | Rick Covalt [ Sat Apr 05, 2014 10:45 am ] |
Got her all warmed up without incident. It took a while for all crap to burn off the header wrap. I think the neighbors thought it was on fire! I guess it is fine. 10# per 1000 rpm, and I am right there. Oh yeah, 10/30 oil. I could probably try 5/20 and then maybe not be loading that oil pump gear so much. Rick |
| Author: | Rick Covalt [ Sat Apr 05, 2014 11:09 am ] |
I also made a heat shield to try and keep a little heat off the carb ![]()
| Author: | Dart270 [ Sat Apr 05, 2014 2:35 pm ] |
Great news! Congrats. 55 psi is fine in my book. Lou |
| Author: | Romeo Furio [ Sat Apr 05, 2014 7:12 pm ] |
Yea, right on the number. I have one of Doc's pumps on my latest car.Street driven all warmed up you should see about 40-ish at idle.One thing for sure it shows instant pressure at start. No dry starts here. |
| Author: | Rick Covalt [ Mon Apr 07, 2014 5:57 pm ] |
I got the car all warmed up again this evening and ran the valves again hot. I got to checking and I had two rocker shaft bolts that were not completely tight. Re-torqued the head gasket and then verified that all my pushrods were spinning and that I have plenty of oil up top. Left her run for about a half hour and had no water leaks or oil leaks that I could see. She sounds good and I am feeling better. Going to try and swap out my 4.56's and go do some T&T Saturday! Thanks for listening! Rick |
| Author: | Rick Covalt [ Thu Apr 10, 2014 1:16 pm ] |
Final warm up before blast off!! It needs to have some new fuel put into it and get rid of the race gas. It doesn't need 110 octane for sure. Off to the garage to install the 3.91"s and then I should be ready. Rick 3.91's are installed (also had to change out the U-joint due Large yoke on the 4.56's) Washed her up and got her all clean. Now it's ready to race!! Anyone who wants to come to Mason Dixon with me Staurday is more than welcome. I will be by myself so come on out !! I'll let you take a picture!! |
| Author: | bmimken [ Fri Apr 11, 2014 1:55 am ] |
Rick, Go get some practice time on the tree. If you redlight during the slant race eliminations in May, I will flog you in public and put you in the stockade!!! Brian |
| Author: | Rick Covalt [ Fri Apr 11, 2014 2:44 am ] |
Quote: Go get some practice time on the tree.
I'm on it!! Quote: I will flog you in public and put you in the stockade!!!
And I'm skeered
| Author: | slantzilla [ Fri Apr 11, 2014 8:43 am ] |
And I'm skeered |
| Author: | Rick Covalt [ Sat Apr 12, 2014 5:14 am ] |
Just in case someone was looking for me at the track, I am not going racing today. I have been sick for 5 days plus it rained all night. So I'll go later this month. |
| Author: | slantzilla [ Sat Apr 12, 2014 10:06 am ] |
That sucks Rick. Hope you get better soon. |
| Author: | Rick Covalt [ Sun Apr 27, 2014 1:06 pm ] |
Went to the track today. Mason Dixon was full today and I only got in 2 T&T runs. Both were nearly identical. 15.46 @ 85.8 and 15.48 @ 86.0 with 2.16 60 fts. I was shifting at 5200 so there is probably a tenth or two left in it, but I see no reason to run it to 5800-6000. I did have a flutter probably around 4000-4500 and then it smooths out and pulls normally on up to my shift point. Any ideas? I run my car in and out of my garage dozens of times between races, and I was thinking maybe the plugs are a bit fouled? I have had this same thing happen before and it usually only happens on my first run. Then it would be fine after that. Today it did it on both runs. I had a new set of plugs, but forgot and left them at home. Good news! It made it down the track and drove itself back onto the trailer. All and all a good day. May 17th here we come. Rick |
| Author: | Greg Ondayko [ Sun Apr 27, 2014 4:21 pm ] |
Quote: Went to the track today. Mason Dixon was full today and I only got in 2 T&T runs. Both were nearly identical. 15.46 @ 85.8 and 15.48 @ 86.0 with 2.16 60 fts. I was shifting at 5200 so there is probably a tenth or two left in it, but I see no reason to run it to 5800-6000.
check your rotor tip and contact tips in t the distributor cap.. I would always have a bit of trouble with that when I ran the distributor on ruster.. oil & cranks case fumes create scum on the contacts.. I would scrape em clean and then it would run better again.I did have a flutter probably around 4000-4500 and then it smooths out and pulls normally on up to my shift point. Any ideas? I run my car in and out of my garage dozens of times between races, and I was thinking maybe the plugs are a bit fouled? I have had this same thing happen before and it usually only happens on my first run. Then it would be fine after that. Today it did it on both runs. I had a new set of plugs, but forgot and left them at home. Good news! It made it down the track and drove itself back onto the trailer. All and all a good day. May 17th here we come. Rick it might be the solution to your problem, but it It can't hurt to check. Greg |
| Author: | Rick Covalt [ Mon Apr 28, 2014 1:44 pm ] |
Thanks Greg, I'll check it out. Have a very small antifreeze leak, and I can't see for the life of me where it is coming from! About 1 teaspoon after shutdown and leaving it set. I need to get a pressure tester. Rick |
| Author: | Greg Ondayko [ Mon Apr 28, 2014 3:02 pm ] |
Quote: Thanks Greg, I'll check it out.
that happend to me once.. on a sleeved block.. the water was leaking past the sleeves and into the oil Have a very small antifreeze leak, and I can't see for the life of me where it is coming from! About 1 teaspoon after shutdown and leaving it set. Rick Greg |
| Page 52 of 128 | All times are UTC-07:00 |
