| Rob's 1981 Dodge Challenger https://slantsix.org/forum/viewtopic.php?t=46322 |
Page 52 of 61 |
| Author: | Dart270 [ Fri Aug 16, 2024 2:42 am ] |
| Post subject: | Re: Rob's 1981 Dodge Challenger |
Very cool, Rob. 50 lbs is worth a lot at that weight range... Lou |
| Author: | Rob Simmons [ Sun Aug 18, 2024 11:11 pm ] |
I made quite a bit of progress on the Challenger this evening. Water pump and most hoses are done. I re-routed and changed around some wiring due to the fuel cell, water pump and radiator all being in different places. I installed the torque converter bolts with loc-tite (after I cut an access hole in the bottom of the bellhousing. I moved the shifter cable over to the passenger side, running it under the bellhousing/oil pan area. I’ve done it that way on the Duster, ToadRacer and a couple others with headers and it has worked well. YMMV. Oh yeah… I also added some lightness… The section I cut out of the bellhousing was 1 ounce and the unneeded shifter rod bracket was another 5 ounces… Just another 1,594 ounces to go to cut a tenth… |
| Author: | Dart270 [ Mon Aug 19, 2024 3:37 am ] |
Woohoo! Go Rob! |
| Author: | Rob Simmons [ Mon Aug 19, 2024 2:53 pm ] |
Howard will be here in the morning. I told him I was working on the radiator and hoses… He said I’m just scared not to run water… Lol. They haven’t run water in Hillside Six for many years. He says all the tractor pull guys do that… |
| Author: | slantzilla [ Mon Aug 19, 2024 4:35 pm ] |
You can do that on akeehaw. |
| Author: | Rob Simmons [ Mon Aug 19, 2024 9:26 pm ] |
Even if it ain’t got one of them high falootin’ billet aluminum heads on it…? They just have a couple fans that blow air at the front of the engine… One of my jury rigged fittings is leaking… and that WOULD cut some decent weight off the nose of the car…. |
| Author: | Rob Simmons [ Tue Aug 20, 2024 8:48 pm ] |
Howard just headed home. I think I’m ready… |
| Author: | slantzilla [ Wed Aug 21, 2024 6:30 am ] |
Did he beat you with a hammer too? |
| Author: | Rick Covalt [ Wed Aug 21, 2024 9:13 am ] |
Woo Hoo!!! |
| Author: | slantzilla [ Wed Aug 21, 2024 10:50 pm ] |
I have a whole box of chips. I got you covered. |
| Author: | Rick Covalt [ Thu Aug 22, 2024 3:44 am ] |
I had a bag of chips but I ate them yesterday Glad it sounds good! It will probably feel good too! I'm excited for you. |
| Page 52 of 61 | All times are UTC-07:00 |
