| 1972 Dodge Colt https://slantsix.org/forum/viewtopic.php?t=63924 |
Page 52 of 81 |
| Author: | Rick Covalt [ Sun Jan 14, 2024 11:26 am ] |
| Post subject: | Re: 1972 Dodge Colt |
Yeah, I worked the inside of mine until I could take a small propane torch and just keep making it warmer and warmer and it would go on with very little effort. Also put a little never seize on the shaft. |
| Author: | hyper_pak [ Sun Jan 14, 2024 12:14 pm ] |
I used some anti-seeze, didn't seem to help. I will post a picture. |
| Author: | Rick Covalt [ Sun Jan 14, 2024 2:17 pm ] |
Stan, Please forgive me I was having an old timers moment. I used the propane torch and never seize on my crank gear, not the Damper, to get it off and on easily. |
| Author: | Badvert65 [ Sun Jan 14, 2024 5:48 pm ] |
Is that the damper with the Steel hub or the Aluminum hub? |
| Author: | slantzilla [ Sun Jan 14, 2024 11:19 pm ] |
That's ugly. |
| Author: | hyper_pak [ Mon Jan 15, 2024 8:21 am ] |
Quote: Is that the damper with the Steel hub or the Aluminum hub?
Steel ROMAC.
| Author: | hyper_pak [ Mon Jan 15, 2024 8:22 am ] |
Quote: That's ugly.
Agreed.What are you using? |
| Author: | slantzilla [ Mon Jan 15, 2024 10:08 am ] |
I have stock dampers on all my junk. I think I have accumulated 3 Fisher dampers, but never used any of them. |
| Author: | Rick Covalt [ Mon Jan 15, 2024 4:21 pm ] |
Quote: Steel ROMAC.
That is what I run too
| Author: | Dart270 [ Tue Jan 16, 2024 6:49 am ] |
I have run 3-5 Romacs, all steel. Never did that... Lou |
| Author: | hyper_pak [ Tue Jan 16, 2024 7:52 am ] |
Quote: I have run 3-5 Romacs, all steel. Never did that...
Yea oh course, it happens to me.
Lou |
| Author: | Badvert65 [ Tue Jan 16, 2024 11:39 am ] |
What does the crank snout look like? Is it missing a chunk? |
| Author: | Greg Ondayko [ Tue Jan 16, 2024 12:56 pm ] |
I have never seen a cam dowel break. that is crazy. Greg |
| Author: | Dart270 [ Tue Jan 16, 2024 1:21 pm ] |
Bob Dally had one break on his Bonneville Barracuda 170. My guess is the bolt was not sufficiently tightened and/or loctited, at least in Bob's case. I always go 60-70 ft-lbs with mine and use loctite and have never seen this. One time I was out of loctite and I used JB Weld. I've heard of a couple more incidents like this, but it is rare. Lou |
| Page 52 of 81 | All times are UTC-07:00 |
