| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 57 of 128 |
| Author: | Rick Covalt [ Sat Feb 06, 2016 4:33 pm ] |
Quote: I will guess that it will allow the use of a late A body pan.
Correct. Where the original K frame swings around the front of the pan, I had it notched back and then re-inforced it with 1/4" plate. This along with the V-8 centerlink should allow me to use the later oil pans . Early pans are getting harder to find cheap. This way I can modify one of the later pans that I have to hold a little bit more oil.Ron I think the only thing that needs to be changed is the centerlink. I do not think they are available in the aftermarket. I got mine up at Carlise in 2014. Guy was asking $60 for it (good price),but I got it for $40. (Better price) As for the trophy, I am pretty sure that that would be a long shot of epic proportions! But I will do my best, not to red light! I would really like to make it to Clay city as well, even if I have to drive the truck. Especially if Ryan gets to come with Seymour's car. |
| Author: | Rick Covalt [ Thu Feb 25, 2016 3:57 pm ] |
Spoke to the Engine shop today and they have ordered all the bearings for both mine and Ryan's new engines. Mine is ready for final assembly and as soon as they finish up a few more dirt track engines mine will go together. He said probably in 2 weeks. I am going to go up and help them when they put it together! (Probably more watching than anything) Making some progress. |
| Author: | 65 dartman [ Thu Feb 25, 2016 4:12 pm ] |
Quote: I think the only thing that needs to be changed is the centerlink. I do not think they are available in the aftermarket.
They are now from Firm Feel (I think). Something like $250 - Yowser!
| Author: | Rick Covalt [ Thu Feb 25, 2016 6:09 pm ] |
That is out of my price range for a center link! |
| Author: | slantzilla [ Thu Feb 25, 2016 6:15 pm ] |
That's more than I'd give if it had the early A body attached to it. |
| Author: | Dart270 [ Sun Mar 06, 2016 5:36 am ] |
Nice, Rick! Lou |
| Author: | Rick Covalt [ Sun Mar 06, 2016 6:34 am ] |
I believe I copied yours Lou! |
| Author: | Dart270 [ Sun Mar 06, 2016 10:37 am ] |
Quite similar, yes. Simple and effective... Lou |
| Author: | 65 dartman [ Sun Mar 06, 2016 12:34 pm ] |
If you could have found an A100 driver's side bracket/adjusting strap, would that have worked? |
| Author: | Rick Covalt [ Sun Mar 06, 2016 12:43 pm ] |
Maybe, but I'm not sure what they look like? |
| Author: | slantzilla [ Sun Mar 06, 2016 6:43 pm ] |
Just about like that. Cool stuff Rick. |
| Author: | Rick Covalt [ Thu May 19, 2016 4:33 pm ] |
I ran the car at Mason Dixon and it ran well all weekend except the dreaded flutter came back. Intermittently, which makes it bad. Pretty sure it is a carb issue when the secondaries open. Because I unhooked the secondaries again and it ran 6 or 7 runs perfectly fine. Actually with no other changes it ran its best ever in this configurations of a 15.09 @ 88. I immediately noticed that when I was running just the 2 barrels the A/F gauge was rock steady the whole way down the track. It was reading 11.7-11.8. So even with just the 2 barrel it is too rich. Sooo, professor Lou said to adjust the primaries to get to 12.5 first, then play with a smaller secondary jet. Made sense to me! Always something to do. Knee surgery tomorrow for one thing! Rick |
| Author: | Dart270 [ Thu May 19, 2016 4:43 pm ] |
Good luck with the surgery, and I very much hope that clears up some pain for you, Rick. I wonder if the secondaries are rich enough to give you some misfire, which makes the AF look leaner than it actually is. Slant on, Lou |
| Author: | slantzilla [ Thu May 19, 2016 6:26 pm ] |
Good luck with the knee surgery Rick. Tell me again how easy those Edelcarters are to tune. |
| Page 57 of 128 | All times are UTC-07:00 |
