| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 58 of 128 |
| Author: | Rick Covalt [ Fri May 20, 2016 2:55 am ] |
Quote: Tell me again how easy those Edelcarters are to tune.
Pretty sure I felt that one coming on! |
| Author: | slantzilla [ Fri May 20, 2016 8:59 am ] |
| Author: | Badvert65 [ Fri May 20, 2016 10:25 am ] |
Love that alternator mounting setup. Where did you get the alternator? I have seen a few 'one wire' mini alternators on e-bay for cheap. Those are listed as around 6 lbs, and 35-70+ amp output. I weighed the one I got from an 86 Dodge truck and it looks similar but weighs in at 11 lbs (a standard dual-field Mopar one weighs in at 13lbs). |
| Author: | Greg Ondayko [ Fri May 20, 2016 2:34 pm ] |
Quote: Good luck with the knee surgery Rick.
Yes good luck with the surgery. Tell me again how easy those Edelcarters are to tune. Those are easy to tune if you actually look at the af gauge. Greg |
| Author: | slantzilla [ Fri May 20, 2016 3:35 pm ] |
Anything is easy to tune with an A/F gauge. |
| Author: | Rick Covalt [ Fri May 20, 2016 3:54 pm ] |
Knee surgery went fine! 2 weeks off work. That's fine with me. That will give me time to rest up for Bristol! Greg alludes to the fact that I can make multiple runs and never look at the gauge. I get in a zone when racing. It's called the Twilight Zone! I do need to get one for in my truck too. Rick Alternator was from E-Bay, 40 0r 45 Amps. |
| Author: | Dart270 [ Sat May 21, 2016 9:11 am ] |
Glad to hear the surgery went well, Rick. Lou |
| Author: | Rick Covalt [ Tue Aug 02, 2016 6:32 pm ] |
Well it has been several months since my new race engine has been in the news! |
| Author: | Badvert65 [ Tue Aug 02, 2016 6:49 pm ] |
Rick, you have my sympathy. Machine shop here has had my dang head for almost 10 weeks now, and I still don't have it. I just don't understand sometimes. |
| Author: | Dart270 [ Wed Aug 03, 2016 9:06 am ] |
Sounds like good progress and I like the plans all around. 12s are in your future... Lou |
| Author: | Rick Covalt [ Wed Aug 03, 2016 9:48 am ] |
I have my helmet all polished up and ready to go. |
| Author: | Exner Geek [ Thu Aug 04, 2016 5:36 am ] |
Did they allow for the additional head milling when figuring the valve notch depth? |
| Author: | Rick Covalt [ Thu Aug 04, 2016 10:01 am ] |
Yes they did. And I had over .200 clearance if I recall what they told me correctly. |
| Author: | Dart270 [ Tue Sep 06, 2016 2:25 am ] |
Excellent progress and results, Rick! Looking forward to seeing and hearing the new motor run. I am not surprised about the cyl wall thickness - nice. Congrats again about the race win too. When I was practicing and had a good consistent car to run, I would be in the 0.00 to 0.07 range of reaction time with a lot of 0.02-0.04s. Been a while... You are doing very well! I have seen good footbrakers hover around 0.00 to 0.03 when in practice. To me, once you have a consistent vehicle, then repetition is the next thing. I am not sure about a technique to practice except that you need to make yourself consistent, then adjust the stall RPM or other parts of the staging to make changes or improvements to RT. See you at M-D if not before! Lou |
| Page 58 of 128 | All times are UTC-07:00 |
