| A new bullet https://slantsix.org/forum/viewtopic.php?t=28649 |
Page 7 of 20 |
| Author: | Joshie225 [ Sun Sep 21, 2008 10:56 pm ] |
Smokin! Nice Job! Can you do a quick run down on the combo as it is today? I haven't kept up with the changes. |
| Author: | Shaker223 [ Mon Sep 22, 2008 6:01 am ] |
| Post subject: | Re: Went Racing Again! |
Quote: Today was a good day for the Valiant! All I did from the 12.00 combo was put on the different turbo and a bigger #10 meth jet and it turned a 11.588 @ 115.66. This is still at 16* total timing and washer fluid blend. I changed to 100% meth and went to a 11.556 @ 116.23. We had a long rain shower so the sun was setting as I ran the final run which is the best ever.
Get them 2nd-dairys open & working!....Even though you didn't see an ET change with the meth, it looks like you did see a MPH increase. Small but still an increase (this tells the HP increase, not the ET) and like you said...an improvement in the AFR.60' - 1.639 330' - 4.710 1/8 - 7.311 mph - 93.84 1000 - 9.565 1/4 - 11.487 mph - 116.92 I must say the 100% Meth didn't help the ET much but it dropped the A/F from 13.3 to 12.2. Over a full point richer. I would still like to see it closer to a mid 11 though. I stayed with miner changes today to do some real comparisons. Still 22 psi and primaries only. It still has the bunny hop but the best 60' today went down to a 1.60. Although not on my best run. Had alot of fun today with this Slant getting lots of attention! Later. Way to go, VERY nice numbers. |
| Author: | Dart270 [ Mon Sep 22, 2008 8:10 am ] |
Wow. Keep up the great work! We are scheming for a central US race location for next year or two to get West and East racers to meet up. KS, NE, or SD would be good places to think about... Lou |
| Author: | Shaker223 [ Mon Sep 22, 2008 9:13 am ] |
Have you tried to work with the secondaries? Have you tried another carb? |
| Author: | turbo66valiant [ Mon Sep 22, 2008 8:24 pm ] |
Thanks guys, Never thought it would be this fast this year. A race fairly close would be great. I sponsor the Sportsman Class here at Oahe Speedway w/ Amsoil Synthetics so I do have some pull here at this track if you guys would like it this far north. They are really open to ideas like this. Let me know if I can help out. Here is a quick run down on the combo: Standard bore 225 (swather) stock deck ht, stock crank, bearings & oil pump (45 psi), all 1972 vintage. TRW Forged w/ speed pro moly rings Comp cams pushrods Dual springs w/ e-bay stainless 1.70 in / 1.44 ex 1970 head - uncut surface (just cleaned), Bowl port, no gasket match Erson turbo cam & lifters - 114 lobe sep - installed at 101.5 (rec at 110) Stock computer controlled Dist (no weights) - 16* Orange box w/ MSD blaster coil and wires Custom Header w/ 3" turbo inlet and 3" outlet Garret T70 Turbo w/ stage 5 wheel - .58 hot - .70 cold - P trim Greedy BOV - China wastegate Divided carb bonnet BG Demon BT 575cfm - only using 1/2 Devils own Meth w/ 100% meth - #10 jet Ebay intercooler and plumbing GER 4000 stall 727 trans - Manual Valve body Stock rebuilt susp w/ drums on all 4 (4" bolt pattern also) 8 3/4 3.23 spool Aeromotive A1000 pump and boost reg w/ return and cell Amsoil 20w50 racing oil - Amsoil Super Shift (trans) - Amsoil 75w90 Severe Gear in rear 26x8.5x14 ET Drags I hope this helps if someone else out there is contemplating a turbo build. I shift at 5500 and traps are 5500. It took a few years of collecting parts on e-bay and jegs to get a list like this. Later Ryan |
| Author: | 66aCUDA [ Tue Sep 23, 2008 6:09 am ] |
Hey Ryan How come so thick an oil??? I would think you could pick up some speed with a thinner oil and if you turbo is oil cooled wouldnt it like thinner oil as well?? Thanks for all the updates we enjoy watching your build, Frank |
| Author: | MJF [ Tue Sep 23, 2008 6:41 am ] |
60' - 1.639
Wow, very good numbers 330' - 4.710 1/8 - 7.311 mph - 93.84 1000 - 9.565 1/4 - 11.487 mph - 116.92 |
| Author: | turbo66valiant [ Tue Sep 23, 2008 9:22 pm ] |
Hey Frank,I have tried 10w30 petroleum and synthetic in this car and the 20w50 seems to keep the engine temps alittle lower. I had heard about quicker spool with a lighter oil but it didn't work for me. Also, the added (not noticable) hp you get with a lighter oil to me isn't worth it. I figure if I'm puting just under 2 HP per cubic inch, the best insurance is the best oil I can get. I've used the Amsoil Racing 20w50 for years in all my performance cars from 2.2L turbos, small blocks and bigblocks with no problems. I would like to get it dynoed sometime but the closest chassis dyno is 2 1/2 hrs away and $100 per hr. Later |
| Author: | 66aCUDA [ Wed Sep 24, 2008 6:19 am ] |
Done blame you there. I would also go with what works...WOW 20-50 in a 2.2 Can we say windage. LOL You certianly have a BOSS ride. Frank PS Keep on RACIN |
| Author: | boosted [ Mon Sep 29, 2008 2:10 pm ] |
I am in the process of starting a turbo /6 setup in my 65 Dart. With that said I cannot comment on your setup but will say i had problems on a few beetles that where blow through that just did not like any boost over 8 psi on a vac secondary carb. It would actualy move the secondary flaps under boost and gave us fits.. Changed it to a manual secondary carb and not a problem. This is with the boost refernce in the proper location. Oh and by the way.. Nice setup.. I am going to do a front mount with my dart as I want to keep it looking like grannys car.. |
| Author: | turbo66valiant [ Mon Sep 29, 2008 9:06 pm ] |
I was originally thinking on a vacuum secondary carb (saw a few big wigs using them) but choose this Demon double pumper instead. I'm glad I did, I just need to get the bugs worked out of it yet. I haven't worked on it for a month or so. Goodluck with your build and send some pics. Later. Ryan |
| Author: | sav_dan [ Sat Oct 04, 2008 6:56 pm ] |
What a great read! I found this doing a search for info on a BG 575 blow through carb. I'm in australia and in the process of turboing my 1970 Holden LC torana. I've got a 202ci straight 6 (very similar to a chev inline 6). I would love to get into the 11 seconds! But its gonna be a while till the old girl is all back together, in the process of starting a bare metal respray aswell! I'm leaning towards a the 575 carb, unless someone can give me a better option for around the same price. Finding a read like this gives you that inspiration you need to keep at it! |
| Author: | turbo66valiant [ Sun Oct 05, 2008 5:10 pm ] |
Sweet, I love it. Glad your inspired even though it isn't a Slant Ryan |
| Author: | turbo66valiant [ Thu Nov 27, 2008 3:05 pm ] |
Here are some updated photos of the engine bay. ![]() ![]() ![]()
| Author: | turbo66valiant [ Fri Apr 03, 2009 3:43 pm ] |
Things added this spring are: Slide-a-link rear suspension Rear tubes and bolted slicks Things to do this week: Roll bar, seat and belts Alum Radiator and hoses Calvert front shocks Later Ryan |
| Page 7 of 20 | All times are UTC-07:00 |
