Terry Littlejohn's Dusters
https://slantsix.org/forum/viewtopic.php?t=5432
Page 7 of 10
Author:  terrylittlejohn [ Sun Aug 18, 2019 5:35 pm ]
Post subject:  Re: Terry Littlejohn's Dusters
Image Image
Author:  Dart270 [ Sun Aug 18, 2019 5:54 pm ]
I can't quite tell from the pics, but it looks like you do not have an accel or decal baffle in there. Maybe when you hit the brakes or accel WOT it uncovers the pickup? Anyway, I would try 6 or 7 qts. Can you take it out on the road somewhere and nail it and then hard brake?
Author:  terrylittlejohn [ Thu Aug 22, 2019 3:16 am ]
yes it is baffled, just showed some pictures of constructing it! i have two pan`s like, one has a stock pickup with a trap door that handles accel and decal also front and rear baffles the other has a swinging pickup haven`t used this one racing yet! just finished going through the engine for this weekend. got the dist set at 18degs had it at 22degs at the track had too pull it and drop it to get the timing back. had a bad surge at idle noticed that when timing is 24degs or more the engine surges, I have the vac adv hookup which bring the timing up to 38degs, this new cam with 114degs lobe separation seems to want less timing than the 108deg cam that it replaced. retorqued the head got a lot of turns on some studs set at 75ftlbs. lash was still dead on int .016/ex .020 those locknut are working great.
Author:  terrylittlejohn [ Thu Aug 22, 2019 3:33 am ]
Image Image can`t find any pictures of the inside of the pan I am running now!! this is the swing pickup pan.
Author:  Dart270 [ Thu Aug 22, 2019 3:54 am ]
Cool swinging pickup pan! I bought one of those pickups a while back, but have never tried it. Not sure it would hold up to long term street usage.
Thanks for posting the pics...
Author:  terrylittlejohn [ Fri Aug 23, 2019 9:03 am ]
going to try the swing pickup on my street car, when I get back at it! haha, between racing and house repair!! :roll:
Author:  terrylittlejohn [ Mon Aug 26, 2019 5:28 am ]
another race weekend and rain!! Saturday!! Sunday was great got somethings straighten out, started with 18degs timing with a 7.17et , then 15degs and a 7.25et. so when back to 22degs but I also pushed launch rpm to 3500 which gave me a 7.09et so last run with the same 3500rpm launch got a 7.02et!! fastest yet. this 6.90et is fighting me for sure! :| https://youtu.be/0U042Q4i9Vg watching video looks like 80psi oil pressure and 12 to 13 psi boost! oil pressure still having a wide swing not sure if cutting the 3 coils off the pressure spring has any thing to do with that??
Author:  slantzilla [ Mon Aug 26, 2019 6:33 am ]
Good luck on getting that 6! :mrgreen:
Author:  Dart270 [ Tue Aug 27, 2019 5:39 am ]
Congrats! Wonder if pressure spring could too short and floating in the relief valve bore??
Author:  terrylittlejohn [ Tue Aug 27, 2019 7:42 am ]
thinking the same thing Lou!! have to call SCP , the springs were only $3usd but the guy said shipping would suck??? Image
Author:  terrylittlejohn [ Sun Sep 08, 2019 3:58 pm ]
Image Image Image no racing this weekend had body work to do!!
Author:  Greg Ondayko [ Sun Sep 08, 2019 4:50 pm ]
Cool stuff Terry!
Thanks for sharing.
Author:  terrylittlejohn [ Thu Sep 12, 2019 9:22 am ]
usually don`t get this far into body work in the summer but after all the rainy weekends and the damage to the front of the car it`s all most finished! Image Image Image
Author:  Rob Simmons [ Thu Sep 12, 2019 11:59 am ]
Very cool! What material did you use for the grill?
I need to make one for the Challenger.
Author:  terrylittlejohn [ Thu Sep 12, 2019 12:37 pm ]
just paint and pin strip! then clear coat!
https://www.flickr.com/photos/184407130 ... ed-public/
Page 7 of 10 All times are UTC-07:00
