It is currently Fri Nov 13, 2026 1:12 pm
Post new topic  Reply to topic  [ 92 posts ]  Go to page Previous 1 … 3 4 5 6 7
PostPosted: Mon Mar 04, 2019 6:38 pm
Car Model: 1964 Valiant
What is meant by a 'CNC' head? Does that mean a head milled from a block of aluminum as opposed to casting?
The single biggest obstacle in that is you're very limited in how to create water jackets....on a cast head - iron or aluminum - the jackets are running in places you can't reach with a machine tool. Most milled heads I've seen are dry heads meant for very short term use....not what you'd want on a Slant Six, most likely.
Present the design to some well known Mopar engine guru and get them to endorse the project so you could have some legacy built-in - not that they'd contribute very much to the design,
I had a Mopar guru oficiando use one of my Slant 6 products in a Mopar magazine article....does that count! LOL
If you were able to get 100 heads into production, you'd be the guru! Most of the older engineer designers have died. I don't know if big personalities rule in Detroit anymore.
PostPosted: Tue Mar 05, 2019 2:27 am
Car Model: 64 Valiant
It's worth taking a look at it again. I need to create a 3D model of a single cylinder and make a hands on sample. The key is to make it compatible with existing intakes and headers so no custom pieces will need to be purchased by the end user.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
