| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 61 of 128 |
| Author: | Rick Covalt [ Wed Oct 12, 2016 10:09 am ] |
I believe it ran a 14.94 and that new found .10 was likely due to the 60 pounds less weight in the car with Ryan driving! Car has ran the last 3 seasons without a hitch and it may actually make an appearance in the race truck. Not totally sure. |
| Author: | Greg Ondayko [ Wed Oct 12, 2016 11:16 am ] |
I surmise that that tenth was due to the spectular Air, Good Barometric Press, Average Humidity and Lower temps! Greg |
| Author: | Rick Covalt [ Wed Oct 12, 2016 1:18 pm ] |
All true Greg! But loosing 60 could'nt hurt |
| Author: | slantzilla [ Sat Jan 07, 2017 11:58 pm ] |
I have a Jeffrey pan down at the shop. Unfortunately, I won't be going down there for a week or two. I also have one of those advance plates I am going to use on my 340. Nice looking piece, we'll see how it works. |
| Author: | terrylittlejohn [ Sun Jan 08, 2017 7:08 am ] |
where do you get those limiting plates? great idea, saves welding filing to get where you want to be. |
| Author: | slantzilla [ Sun Jan 08, 2017 9:13 am ] |
I got mine from Mancini, but FBO makes them, and I think they are cheaper from FBO. |
| Author: | Rick Covalt [ Sun Jan 08, 2017 2:36 pm ] |
FBO web site below. http://4secondsflat.com/ |
| Author: | Dart270 [ Wed Jan 11, 2017 6:01 am ] |
Very nice work. Looking fwd to M-D race in May. Their site says the 20th for Mopar show. This would be the first year that is not overlapping VT graduation - nice. Lou |
| Author: | Rick Covalt [ Wed Jan 11, 2017 1:24 pm ] |
I am amazed at how little effort it takes to spin over this long block. I hope that converts to more horsepower. |
| Author: | Dart270 [ Wed Jan 11, 2017 5:59 pm ] |
Try putting a small torque wrench on it and see what the torque is. My cast cranker with wiseco/K1s had 10 ft bls to break it loose, then about 7-8 lbs to keep it turning, all before break in. Slant on, Lou |
| Author: | Rick Covalt [ Wed Jan 11, 2017 6:44 pm ] |
Will do! |
| Author: | Dart270 [ Sun Jan 15, 2017 4:26 am ] |
Rick, Nice work so far on the pan and cleaning. You will need to extend the pickup a bit more than 1" due to the angle involved there with the Slant and the pan floor. Also, another pickup hole does not mean more oil. The bigger the area on the pickup, the easier it is to uncover part of the pickup and suck air. Once you get even a tiny bit of the opening(s) exposed to air (no oil, accel, braking, cornering) then air will be drawn up much easier than oil and you will at best have air in your oil and at worst low or no oil pressure. The best thing is to figure out where you can place the hole in the pickup on the floor so that oil slosh does not uncover it. Oh, is this for your Valiant? If so, I'm not sure you can extend the sump rearward w/o hitting the drag link on hard steering. Did you measure this first? Just want to make sure... If this is a Volare pan, then I think you can. Stock 65 Val pan, nope. Best, Lou |
| Page 61 of 128 | All times are UTC-07:00 |
