| Help with Radio Interference https://slantsix.org/forum/viewtopic.php?t=10004 |
| Author: | 69a100 [ Mon Aug 02, 2004 3:47 pm ] |
| Post subject: | Help with Radio Interference |
Username is vehicle in question with a /6, Ive done radio swaps, swapped alternators, grounded the radio, grounded everything else, even installed a noise suppressor on the Alt. Power line and then swapped it to the radio power line and I still get interference that varys with engine speed. If I disconnect the Alt power line the noise stops, What can be causing this and what do I do to make it stop? Im at my wits end with it!!! |
| Author: | RMDV [ Thu Aug 05, 2004 9:03 am ] |
| Post subject: | Radio interference |
Sounds like you have a leaking diode on the alternator rectifier circuit. Do you know that the second alternator you installed was operating properly or could it be plagued with a problem the same as the first one? RMDV |
