It is currently Thu Nov 26, 2026 10:48 am
PostPosted: Thu Jun 10, 2004 4:11 pm
I got the upper control arm off, now I'm trying to get the LCA. All my manual says is to loosen the tension on the control arm and then disconnect the torsion bar from the LCA. I loosened the tension and tried to disconnect the torsion bar from the LCA, but it won't go. Can someone tell me how to do this?
Thanks!
PostPosted: Thu Jun 10, 2004 4:13 pm
and it's a 73 Dodge Dart with 10 inch drums
My car may be slow to sixty, but at least it's been reliably slow to sixty for more than thirty years.
PostPosted: Thu Jun 10, 2004 7:04 pm
Actually if you remove the nut and washer on the LCA pivot, you can then drive the whole works rearward a few inches. Then this relieves the binding condition on the torsion bar and it will slide right out.
PostPosted: Thu Jun 10, 2004 8:20 pm
Thanks, that and a couple of previous post I was able to turn up helped a lot.
PostPosted: Sun Jul 18, 2004 12:24 pm
"Actually if you remove the nut and washer on the LCA pivot, you can then drive the whole works rearward a few inches. Then this relieves the binding condition on the torsion bar and it will slide right out."
I tried the above steps, but couldn't move the pivot stud back.
I loosened the strut rod nut and was able to drive the pivot back.
Observed definite movement of the t-bar at the rear socket, but no movement in relation to LCA.
(I am trying to just remove the torsion bars and install different ones)
How do I separate the t-bar from the LCA ?
:cry:
 Post subject: removing torsion bar
PostPosted: Thu Aug 05, 2004 12:51 am
After removing the clip on rear part of torsion bar try
a bicycle handlebar stem clamp , the part that holds the
handlebar fits good on the torsion bar, titen the clamp
to torsion bar then hammer on the clamp rearwards.
also some penetrating oil inside the lower arm/torsion
bar area may help. I got my handle bar clamp from
bikes thrown out on side of road.
