| How low can I go with .870 torsion bars? and moog question https://slantsix.org/forum/viewtopic.php?t=10090 |
| Author: | sixsignet [ Wed Aug 11, 2004 10:51 pm ] |
| Post subject: | How low can I go with .870 torsion bars? and moog question |
Switching from stock .830 to .870 bars. How low can I go with these? Are those moog problem-solver bushings used solely to compensate for geometry changes when you lower the front end? If so, can I go low enough with .870s to require these special bushings? note: it is a 63 2-dr hardtop =~ 2570 pounds |
| Author: | Dart270 [ Thu Aug 12, 2004 7:46 am ] |
With any T-bars, you can only go as low as the bump stops will allow (unless you modify them). You need at least 3/4" between the LCA bumpstop and the frame contact point, or you will bottom out readily and your suspension will not be useful. The camber/caster does get a bit worse when you lower things, so the problem solver bushings (with one reversed for best caster increase) are a good idea in any case. Lou |
| Author: | MrMopar [ Wed Aug 18, 2004 4:46 pm ] |
This might help. http://www.ingallseng.com/performance/camberchange.htm |
