| How to test? https://slantsix.org/forum/viewtopic.php?t=10094 |
| Author: | ValiantBoyWonder [ Thu Aug 12, 2004 12:43 am ] |
| Post subject: | How to test? |
How do i go about testing an Exhaust manifold for leaks??? |
| Author: | Doctor Dodge [ Thu Aug 12, 2004 7:15 am ] |
| Post subject: | Re: How to test? |
Quote: How do i go about testing an Exhaust manifold for leaks???
Basically you listen for exhaust leaks. A mechanics stethoscope helps or even a long pipe that you can put your ear up to and move into various places. Once you suspect a leak point, wait until the engine is dead cold and start it, then quickly stick your hand near the place you think is leaking, you will feel the hot exhaust gas pressure. Work quickly, you won't have more then 90 seconds to do the "feel test" before the manifold gets too hot to work around. DD |
| Author: | VDART [ Thu Aug 12, 2004 8:57 am ] |
| Post subject: | leak check |
another way is to put tranny fluid in the carb(engine running), pour smallamount at a time, your smoke trail will let you see the leak!!!! good luck! |
