| Trunk mount battery????? https://slantsix.org/forum/viewtopic.php?t=10116 |
| Author: | HyperValiant [ Sat Aug 14, 2004 9:33 pm ] |
| Post subject: | Trunk mount battery????? |
When a battery is installed in the trunk ,should the cable be run through the inside of the car or along the bottom??? HyperValiant |
| Author: | Pierre [ Sat Aug 14, 2004 11:08 pm ] |
If its just a single wire, inside. Otherwise the weather will eventually make it brittle and it will corrode easier. I would never run power wire outside unless it was some sort of SO or similar cord. When I mounted my electric fuel pump on the frame rail just past the rear end, I used 2 conductor SO cord. SO cord has fibers between the individual conductors and an outer shield that is chemical and weather resistant, but such a cord is not suited for a main battery feed because it is not availible in a heavy enough gauge and in single conductors. |
| Author: | Patrick Devlin [ Sun Aug 15, 2004 8:27 pm ] |
If you run the cables under the car, I would recommend doing it through some kind of conduit...like plastic pipe held on with brackets or something. I'll let you know when I do it. |
| Author: | Pierre [ Sun Aug 15, 2004 9:03 pm ] |
At your hardware store, in the electrical section you can find some flexible metal conduit that they use for commercial wiring. That would work well, you wouldn't need a bender or any special tools to use it. Easy to work with, you don't need a hacksaw to cut it |
| Author: | golembieski [ Wed Aug 18, 2004 6:14 pm ] |
I run the ground stap to the frame then ran the battery cable up the inside of the channel and attached it with those rubber coated cable mounts. |
