It is currently Fri Jun 19, 2026 5:05 pm
PostPosted: Tue Aug 17, 2004 10:31 am
Can anyone think of any issues I should be prepared for if I were to want to put the slant 6 and 904 trans from a '62 pushbutton Valiant into a '65 column shift Valiant?
PostPosted: Tue Aug 17, 2004 3:49 pm
The valve body is a little different in '62 vs. '65 to accommodate the lever vs. pushbutton-and-park-slide shifting. Probably easiest to swap the valve bodies.
Other than that, no issue.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
