It is currently Mon Jun 22, 2026 5:21 am
PostPosted: Sat Aug 07, 2004 11:13 am
Does anyone have a vacuum diagram with the vacuum amplifier connections? Mine has been capped off in several places. Thanks!
PostPosted: Sat Aug 07, 2004 1:33 pm
What year, make & model vehicle are we working on?? :?
Do you need a vacuum amplifier or something else?
A little more info would be helpful.
 Post subject: vac diagram info
PostPosted: Sat Aug 07, 2004 3:53 pm
Sorry I wasn't clear in my last post. I have a 73 Valiant with a 225 slant,auto trans. I have a vacuum amplifier,but most of the hoses are blocked off. I need to know how it is supposed to be set up. Even a simple clear sketch would do. Any help is appreciated!
PostPosted: Sat Aug 14, 2004 10:26 pm
i'd need a diagram also...i have a 72 plymouth scamp with a 225 slant six auto...mine is capped off in a lot of places too
PostPosted: Mon Aug 16, 2004 2:58 am
I've not been able to find a vacuum diagram for my 70 Valiant either. I have a Hanes manual but its not in there. Any ideas???
 Post subject: vacuum routing
PostPosted: Mon Aug 16, 2004 4:20 am
Well,
So far,according to many on this site,the thing to do is make sure to keep the line from the dist. to the carb and from the carb to the valve cover port and cap the rest.If you don't have to worry about emissions testing this seems to work nicely!
