| 4bbl question https://slantsix.org/forum/viewtopic.php?t=10134 |
| Author: | guest [ Mon Aug 16, 2004 7:39 pm ] |
| Post subject: | 4bbl question |
I am rebuilding a 600cfm holley for my built up slant. I've found that there are two holes in the main body just below the steel fuel line that connects the fuel bowls. I looked and found that there is supposed to be a balance tube, which I don't have that goes through the main body and into each of the fuel bowls. Does anyone know the purpose of this balance tube? Could I just plug off the two holes in the carb body? I found a diagram at http://www.holley.com/HiOctn/TechServ/T ... 50-60.html the balance tube is #126 in the diagram |
