seeping oil
https://slantsix.org/forum/viewtopic.php?t=10154
Author:  NORM [ Wed Aug 18, 2004 9:25 am ]
Post subject:  seeping oil
i have a slant six engine that is seeping small amounts of oil between the block and head. could this mean i need to re-tourque the head. the engine has a copper head gasket.
Author:  MrMopar [ Wed Aug 18, 2004 10:10 am ]
Are you sure the oil isn't coming from the Valve cover gasket?
Author:  Dart270 [ Wed Aug 18, 2004 10:31 am ]
If it's near the front, it could be the alternator bracket hole (if your bracket's gone), which is open to the outside.
Author:  moparDuster [ Wed Nov 03, 2004 6:31 am ]
i get the oil seeping too and have no idea were it goes from. never knew about a alternator bracket hole. mine looks to be leak between the block and head
this is my first toy i thought i was gona go bigger untill i taalk to a few slant six fans
Author:  Tom Drake [ Wed Nov 03, 2004 7:16 am ]
What type of sealant did you use on the gasket? Where did you put it?
Tom
Author:  MitchB [ Wed Nov 03, 2004 5:41 pm ]
Post subject:  Re: seeping oil
Oh yeah, copper head gaskets are known to weep. Retorque the head.
Mitch
Author:  stinky mctinkerpants [ Sat Nov 06, 2004 10:10 am ]
Post subject:  been in the mess
i have found leaks from the timing cover seal. fuel pump gasket, oil pump gasket, and the various bolts that tap into the motor before, all were decieving.
