| Quicky Flywheel question https://slantsix.org/forum/viewtopic.php?t=10207 |
| Author: | Old Car Scott [ Tue Aug 24, 2004 2:20 pm ] |
| Post subject: | Quicky Flywheel question |
Are the flywheels from a 318 and slant six interchangable? |
| Author: | Dart270 [ Tue Aug 24, 2004 2:49 pm ] |
Quick answer - no. Longer answer - you can use the 318 fly if you drill one crank hole offset and get a big truck/Slant bellhousing to fit it in. Hard to find... Slant fly on a 318 will not work since the starter won't line up - too small in diameter. Lou |
| Author: | sixty4dartgt [ Tue Aug 24, 2004 6:12 pm ] |
I have a '64 flywheel I'm not using if you are interested and need one. I don't think it will fit your Duster though, if it has the original engine. |
| Author: | Old Car Scott [ Wed Aug 25, 2004 9:47 am ] |
Thank you both very much, for the info and the offer! I'm actually looking for a 318 flywheel for a friend. |
