So, Exactly what do I have here?
https://slantsix.org/forum/viewtopic.php?t=10233
Author:  72swing [ Thu Aug 26, 2004 4:08 pm ]
Post subject:  So, Exactly what do I have here?
2 2806830 - engine block, RG-series 225 198, 1968-1970 casting
I used a online MOPAR decoder to obtain this information. What I need to know is some basic Info, IE: Forged/Cast, and what else would be useful when I order a bottom end kit. Additionally, WHERE do I get a crank with matching bearings from? :? Somebody mentioned NAPA?! Their site doesn't even list that they have cranks for the 225, little own with bearings. If somebody has a link or information that would be GREAT!
The Great teardown is getting close at hand and I want to make sure I have all compatible parts when I get going, since time will be at issue. :)
Author:  DusterIdiot [ Thu Aug 26, 2004 5:38 pm ]
Post subject:  You have to go ask or call them...
Your block could be either 198/225 depending on the crnak and rods installed (look at the 'shelf' above the #1 piston for a stamp 198 or 225).
Any Pre-75 will be 'forged' crank, you'll want a 1968-1975 unit.
You call up Napa since the price changes, and ask for a 'Crank Kit' for a 225 slant six, and it has the crank (ask what the grind is .010/.010) and it should come with your main and rod bearings...usually costs about $250 for a 'good kit'....
Author:  moparfreak [ Thu Aug 26, 2004 7:03 pm ]
i'm wondering what the site you used to decode your engine was i'm kinda curios on the original home of my engine
Author:  72swing [ Thu Aug 26, 2004 7:08 pm ]
Hey, The Site is http://www.autohobbydigest.com/numbers.php
The system is pretty effective... and additionally it is the first option when I did a search for mopar part number decoder :)
