| Kickdown Cable? https://slantsix.org/forum/viewtopic.php?t=10234 |
| Author: | ValiantBoyWonder [ Thu Aug 26, 2004 4:44 pm ] |
| Post subject: | Kickdown Cable? |
kickdown cable, how's that work? can you replace linkage with a cable for the carb??? |
| Author: | argentina-slantsixer [ Thu Aug 26, 2004 10:22 pm ] |
LOKAR is a good source of kickdown replace... it works with one end that bolts a support bracket to the drivers side tailhousing of the tranny, then a steel cable with a lever bolted on the kickdown lever on the tranny... depending on your tranny's make year it would be kinda hard to get the thing in, but you'll do it (eventually |
| Author: | jfsram [ Fri Aug 27, 2004 5:26 am ] |
I have one on my truck. It works opposite the linkage. Carb pulls the cable and the cable pulls the kickdown lever on the trans from the rear. Excellent product. Mopar should have implemented these 40 years ago. |
| Author: | Super6 [ Fri Aug 27, 2004 9:27 am ] |
Here it is hooked up to a Holley 4bbl on my truck: ![]() The accelerator cable is on the bottom, the kickdown cable is on top (they pull opposite directions) -S/6 |
