It is currently Tue Jun 09, 2026 9:50 pm
PostPosted: Thu Aug 26, 2004 7:07 pm
I need fuel psi directions, and any other info that would help.I've tried every thing.
PostPosted: Thu Aug 26, 2004 7:19 pm
What is the problem?? Missing, backfires, burned spark plugs, fried engine? :?
 Post subject: nitrous experts
PostPosted: Thu Aug 26, 2004 7:30 pm
Well, I run a single holly blue fuel pump. I run a 1/2 inch line from the fuel tank, and i tee into two holly fuel pumps. one for nos the other carb. I run 5 1/2 flowing on nos and 4.5 on carb. It pops on the high rpms mostly. Can you line me out from start to finish?
PostPosted: Thu Aug 26, 2004 7:51 pm
It sounds like you are going lean on a cylinder or two.
Is this a "fogger" system or a plate under the carb to feed in the NOS?
What jet sizes are you currently running?
Are your spark plugs new and a cold heat range? Are all the other ignition parts up to the task of "lighting-off" a much denser (and harder to light) cylinder load?
I run a fogger type system with #20 NOS & #22 fuel jet with 5 psi of flowing fuel pressure. I use a MSD 6A, Blaster coil and copper core wires to make sure the charge gets lit.
PostPosted: Fri Aug 27, 2004 3:57 am
I'm running a nitrous works plate system. My plugs are 2 stages colder that stock. Fuel jet is 52 and nitrous jet is 47 for 100 hp. I use accell super stack coil and accell 8mm wires and the stock magnetic pick up distributor.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
