| LCA bushings, grease or no? https://slantsix.org/forum/viewtopic.php?t=10260 |
| Author: | textoad [ Sat Aug 28, 2004 3:06 pm ] |
| Post subject: | LCA bushings, grease or no? |
I'm installing the LCA bushings and strut rod bushings on the K-frame right now and I'm wondering if I should apply some lithium grease on the bushings or some other kind of lube.. The new bushings are polyurethane. I don't want to use something that will deteriorate them. Thanks. |
| Author: | Dennis Weaver [ Sat Aug 28, 2004 3:48 pm ] |
Not only should you, but you must with polyurethane... (lower control arm) The problem will be when that grease dries out and they start "popping" and squeaking... D/W |
| Author: | textoad [ Sun Aug 29, 2004 8:25 am ] |
I looked in the box I had everything in and I found a small tube of "special formula" grease that came with it. Thanks. |
