1 bbl carbs
https://slantsix.org/forum/viewtopic.php?t=10269
Author:  redworm67 [ Sun Aug 29, 2004 10:42 am ]
Post subject:  1 bbl carbs
anyone ever try other types of 1 bbl carbs on their slant,strombergs,zenith,rochesters say off of a corvair.any input especially about duals (offy) will be appreciated..
Author:  Doctor Dodge [ Sun Aug 29, 2004 9:44 pm ]
The linkage & butterfly for a SL6 1 bbl is 90 degrees off when you look at other 1 barrel carbs.
There are Holley, Carter and Stromburg carbs made for the Slant, the Carters are pretty "forgiving" but you can get a little better performance / mileage out of the Holley. The Stromburg "WWW" carb is a real "odd duck" and hard to find. It runs a lot like the Carter.
Author:  mrhite65 [ Mon Aug 30, 2004 1:35 pm ]
I've used a Carter YFA off of a Ford 300-6. I've looked at some other Carters and noticed the AMC Jeep Carter YFA's have the closest linkage to a slant6. I used the 300-6 carb, because it had 220 cfm's.
