It is currently Fri Jun 19, 2026 11:00 pm
 Post subject: 1 bbl carbs
PostPosted: Sun Aug 29, 2004 10:42 am
anyone ever try other types of 1 bbl carbs on their slant,strombergs,zenith,rochesters say off of a corvair.any input especially about duals (offy) will be appreciated..
there is only one...
PostPosted: Sun Aug 29, 2004 9:44 pm
The linkage & butterfly for a SL6 1 bbl is 90 degrees off when you look at other 1 barrel carbs.
There are Holley, Carter and Stromburg carbs made for the Slant, the Carters are pretty "forgiving" but you can get a little better performance / mileage out of the Holley. The Stromburg "WWW" carb is a real "odd duck" and hard to find. It runs a lot like the Carter.
PostPosted: Mon Aug 30, 2004 1:35 pm
I've used a Carter YFA off of a Ford 300-6. I've looked at some other Carters and noticed the AMC Jeep Carter YFA's have the closest linkage to a slant6. I used the 300-6 carb, because it had 220 cfm's.
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
