| Tires on a '70 Dart Custom 4-Door https://slantsix.org/forum/viewtopic.php?t=10307 |
| Author: | StradSixer [ Thu Sep 02, 2004 11:49 pm ] |
| Post subject: | Tires on a '70 Dart Custom 4-Door |
It's recently come to my attention that my tires need replacing. My question is, aside from the standard size tires, which is what I have, what would be good to put on? I once read somewhere that larger tires on the rear could help my mileage a bit. Any thoughts? Thanks in advance for the help. Casey Rice '70 Dart Custom 4-Door |
| Author: | Thropar [ Fri Sep 03, 2004 7:44 am ] |
| Post subject: | depends |
that depends on what you want to get out of your car, do you want it to be a lowrider, do you want better handling, are you going to the dragstrip, do you want super highway mileage and don't care about off the line performance..? larger diameter rear tire will up your mileage, it changes your final gear ratio... slower off the line, better top speed, speedometer will be off i'm assuming you have 14" rims, i would try out some 205 or maybe 215 60 series tires (depends on how wide your rim is) |
| Author: | StradSixer [ Fri Sep 03, 2004 9:08 am ] |
Well this car is purely a daily driver for me so what matters is mileage. |
Well this car is purely a daily driver for me so what matters is mileage. Thanks for the tip! |
| Author: | Thropar [ Fri Sep 03, 2004 12:18 pm ] |
| Post subject: | diameter |
measure the diameter of the tire before you buy them, there is a formula somewhere on the board to find out the RPM difference for different sizes of tires and gearing |
