| difference between lockup and non lockup 904 https://slantsix.org/forum/viewtopic.php?t=10318 |
| Author: | chi/6er [ Sat Sep 04, 2004 11:40 pm ] |
| Post subject: | difference between lockup and non lockup 904 |
I see some Torque flite 904 trans selling with lockup and some non lockup...what is the difference? which is better for street mainly? |
| Author: | Jeb [ Sun Sep 05, 2004 2:10 pm ] |
The lockup is a lockup torque convertor. It locks at about 45 MPH and does away with torque convertor slippage. It is supposed to give you better fuel economy and increased engine life due to the fact that it drops your RPMs back some and none of the engines power is lost in the convertor. The 727 Torqueflite in my Ram has one and it feels like it shifts four times from 0-60, but the 4th shift is just the torque convertor locking up. |
| Author: | chi/6er [ Sun Sep 05, 2004 11:57 pm ] |
| Post subject: | difference between lockup and non lock |
thanks Jeb....so the lockup or nonlockup is really the torque convertor function.. since lockup is fuel efficent, then non lockup is more performance oriented....... |
| Author: | Doctor Dodge [ Fri Sep 10, 2004 12:39 am ] |
Yes, a non-lock-up is the way to go for a performance engine simply because a lock-up converter will not last long with a lot of WOT shifts. The fact is that most of these transmissions will not let the convereter go into lock-up when you have the gas floored. DD |
| Author: | chi/6er [ Fri Sep 10, 2004 11:15 pm ] |
| Post subject: | difference between lockup and nonlockup |
Thanks Doug.....Jerry |
