will a 3 spd bell housing work with a 4 speed?
https://slantsix.org/forum/viewtopic.php?t=10319
Author:  Guest [ Sun Sep 05, 2004 7:44 am ]
Post subject:  will a 3 spd bell housing work with a 4 speed?
Can I bolt a 4 speed transmission to a 3 speed belhousing?
Author:  Guest [ Sun Sep 05, 2004 8:55 pm ]
yes i did it 30yrs ago in a 64 cuda you have to weld the bellhousing to and a plate for the bolt patern
Author:  Guest [ Sun Sep 05, 2004 8:57 pm ]
yes i did it 30yrs ago in a 64 cuda you have to weld the bellhousing to add a plate for the bolt patern change from 3-4 speed
Author:  DusterIdiot [ Sun Sep 05, 2004 11:13 pm ]
Post subject:  Only with an adapter....
Only with an adapter or having the 3 speed housing re-machined. On many 70's mopars some 3 speed cars came with the 4 speed bellhousing as it is machined with both 3 and 4 speed patterns....
In a quick bolt up, you might not, but check to make sure you don't have an extra set of threaded bolt holes in your bellhousing....
