Head Swap Issue
https://slantsix.org/forum/viewtopic.php?t=10415
Page 1 of 2
Author:  dart63 [ Thu Sep 16, 2004 10:18 am ]
Post subject:  Head Swap Issue
OK, I've replaced my 1963 Dart 225 head (Burnt valves) with a 1977 casting completley reworked, new intake and exhaust manifolds, new fuel pump, Pertronix ignition.
I have adjusted the valves per articles I have read over the past year and they seem to be dialed in. .012 on intakes, .022 on exhausts...yes I know they are supposed to be .010, and .020 respectively however I have been told by more than one reliable source to keep them a little loose because of unleaded gasoline quality.
Probem is, the thing is running crappy, trying to jump out of the engine compartment........
The timing appears to be correct, all plug wires and firing order OK.
When I remove the plugs after running for awhile, they are completley coated with carbon. I asked a mechanic for help at this point and he is telling me that he suspects the original (1963)Carter bbl is probably the culpret due to the fact that this head developes much more vacuum than the old one, and the old Carter is probably not jetted to accomodate.
I did my homework before these modifications and have never heard mention that I would need to update my carburetor. This will become a catch 22 since even to throw on a 1977 single barrel Holley 1945 at this point will require a complete changeout of my throttle and kickdown linkeage. If i'm going to that much trouble, might as well just throw in an aluminum Offy with dual Webers while I'm at it.... :twisted:
Any advice?? Anyone?? The other possibillty I have considered is that the 1977 refurbished head may have issues. I did not have it checked locally after purchase :oops: .
Thanks in advance. http://groups.msn.com/KevsCars/shoebox.msnw
Kevin
Author:  Reed [ Thu Sep 16, 2004 11:00 am ]
Well, for one thing in 1972 all slant six cylinder heads went to hradened valve seats, so your 77 head is designed for unleaded gas. Put thoe valve lash specs back to .010 intake and .020 exhaust.
You describe the engine as wanting to jump out of the engine bay. I will guess this means it is idling and running rough. I would look for a vacuum leak, improperly gapped spark plugs, plug wires not routed correctly, and possibly timing being off. Was it running fine before the swap?
Author:  Guest [ Thu Sep 16, 2004 5:15 pm ]
Did I mention that the new head has an air injection port .....which I sealed off?
Is sealing it off the proper thing to do?
Kevin
Author:  dart63 [ Thu Sep 16, 2004 5:22 pm ]
The car ran fairly well before the swap except for an annoying miss that was attributed to burnt valves.
Also, due to the dreaded exhaust manifold curse more exhaust came out from under the hood than the tailpipe........
The previous owner used the wrong hardware on the manifolds, one stud was missing, and the manifold gasket was pretty much blown to pieces......also, the heat riser valve was frozen open and exhaust was escaping between the manifolds where they meet.
Other than that..........
All is well now with exhaust, runs very quietly, just rough....and lots of blue/black smoke especially cold.
Kevin
Author:  dart63 [ Mon Sep 20, 2004 11:40 am ]
Worked on this all day yesterday....no improvement.........
Any suggestions??
Kevin
Author:  Reed [ Mon Sep 20, 2004 12:29 pm ]
Well, my first guess would be a timing or a vacuum leak issue. If those check out okay then I would suspect the carb.
Black smoke is unburnt fuel, which means you are running too rich. Check your choke settings. If you are sure your ignition system is functioning correctly (did you gap the Pertronix unit correctly?) and you know you have no vacuum leaks, then that leaves the carb or the cylinder head itself. Try rebuildign the carb and leaning it up a bit. :?
Author:  JohnnyDees [ Wed Sep 22, 2004 6:05 pm ]
Nice car. A little off the subject but what wheels are those?
Author:  panic [ Wed Sep 22, 2004 7:27 pm ]
This "mechanic" who told you the head "develops more vacuum".
Was he wearing a white coat with the sleeves tied in the back?
Lying on the floor of a gin mill?
Yelling at you from the window of a building labeled "County Asylum"?
Don't ask him any more questions.
Author:  stinky mctinkerpants [ Wed Sep 22, 2004 10:58 pm ]
Post subject:  something smells fishy
im prone to agree with panic, black smoke= tuning problems with your carb or ignition, BLUE smoke= jacked up valve job from a jacked up mechanic. blue smoke is oil getting cooked and will lead to your symptoms. if you suspect this there is a tool you can buy that basically is an adapter so you can hook a compressor line into your spark plug hole. you gradually increase pressure and slowly rotate your motor through its strokes for each gear listening for escaping air from the breather or dipstick. dipstick=bad rings, breather=bad valves. you might be able to do it just by checking the valves during the compression stroke turning the motor by hand with the valve cover off. I am at a loss because i have never done this myself on a slant maybe another board member has insight to this. Your carb should be fine unless you cleaned it with some horrible solvent or battery acid. richening up the mixture is an old hack answer to engine problems and if you have black smoke then you might be to rich already, the previous owner might have richened it to cure the side effects of exhaust leaking and the valve problems. once again check your timing, it sounds like you have adopted an abused and neglected car and you want to do it right, i know the story thats how i hooked up with the slant board, i too offset the collaberation of messed up work and now im in it, but its worth it for a bitchen ride, and yours looks bitchen
Author:  dart63 [ Fri Sep 24, 2004 6:17 pm ]
The problem definately seems to be fuel mixture too rich and not enough adjustment at the carb to make it right.
I took the carb yesterday for a rebuild and it is ready to pick up tomorrow morning. It is being re-jetted and metered for a leaner mixture. remember.....I am using a 77 head, and a 1963 vintage single barrel Carter Ball & Ball. Call me crazy but emission standards being what they were in 63 (Non-existent) vs. 77 (Unleaded gas, advent of emmissions pumps....etc.) had to mean a tigher leaner carb on the 77's.
I'll see what happens after replacement and let you know.
To answer the wheels question, they are American racing Outlaw II's. Quite nice.
Thanks everyone.
Author:  dart63 [ Mon Nov 29, 2004 11:46 am ]
OK, after yesterday, I can finally bring this to closure but I would still be interested in hearing opinions........
I found that my rough idle problem was due to the fact that my Pertronix Rotor assy had lost it's scotch tape.........yes that is the only thing holding the damn magnets in place :evil: ..so I now have replaced the Pertronix with a brand spanking new Chrysler performance electronic ignition I found on ebay, and constant output voltage regulator from Summit. That took care of the idle but now for the black smoke....too rich condition.
I had the original Carter BBd rebuilt with less jet by a very reputable shop, I replaced it and less smoke but still to rich. So before putting the car into storage for the winter yesterday I decided to throw on a Holley Economaster that I found on ebay new in box, basically a 1920/BBd hybrid so that I could take the BBd back to have the jets and metering lowered again which the shop said they would gladly take care of.
I threw on the Holley and :shock: :shock: :shock: :shock: the damn thing started up, no smoke, no smell no nothin, before even going after the F/A mixture!!!!!
The Economaster is for solid rod linkage from 1960 through 1967 I believe. Why does this carb work right off the bat, but the Carter can't seem to dial in?? The Carter was by the way flow tested after rebuild.....
I am happy that the problem is straigtened out but now more curious than ever as to why??
Kevin
Author:  argentina-slantsixer [ Mon Nov 29, 2004 6:58 pm ]
Ha! :twisted:
Holley beats carter again and again. :lol: :lol: :lol: :lol: :lol:
Author:  dart63 [ Tue Nov 30, 2004 5:51 am ]
Over on Allpar, they always rave about the Carter and try to steer everyone clear of the Holleys.... :?:
Author:  Eric W [ Tue Nov 30, 2004 12:17 pm ]
You answered your own question about the Carter: it was the original carburetor. It was probably so worn out it couldn't be adjusted. Seen it many times on many carbs. Also, loose the constant voltage regulator. They are only used for racing so the ignition gets a constant level of voltage. They don't work for vehicals that are driven on the street, especially if/when you turn on the headlights, radio, windshield wipers, etc. Your car demands more power, but will not get it because the voltage will stay constant.
Author:  argentina-slantsixer [ Tue Nov 30, 2004 12:39 pm ]
What is that about disconnecting the constant voltage regulator? I've always read and heard that this can kill your ecu.... :shock:
I'm interested tho in that information, it may be an upgrade... :roll:
Exactly why and how do you bypass or disconnect your constant regulator? I'm actually running a regulable regulator (li'l box that has a cover that unscrews and you can tweak it to give more or less voltage)
Thanks for the explanation.
Page 1 of 2 All times are UTC-08:00
