| problem with 904 torgue converter https://slantsix.org/forum/viewtopic.php?t=10559 |
Page 1 of 2 |
| Author: | Joug_Fin [ Mon Oct 04, 2004 3:39 pm ] |
| Post subject: | problem with 904 torgue converter |
I have -78 Aspen and it's tranny has been leaking quite a long time. Today I took it out and checked what's wrong there. The torgue converter's 'shaft' (that pipe) has a long break on it. How usual that is, is there anything to do for it , is there any stronger ones??? And, how do I recognize if it is lockup or non lockup converter? |
| Author: | Craig [ Mon Oct 04, 2004 3:58 pm ] |
I was told by a transmission shop that the torque converter "pipe" and also the front clutch are the weak points on those transmissions. Yes, that "pipe" getting cracked/broken is somewhat common. You must replace the complete torque converter assembly. To tell if your transmission is a lock-up or non-lockup -- Look at the smaller splined shaft on the front of the transmission where you pulled the torque converter off of. If the shaft has a deep hole drilled through the center (for oil flow) then you have a lock-up tranny. If there is no hole drilled in the shaft (don't confuse this with a shallow pilot hole that may be in the shaft, a hole that goes no where) then you have a non-lockup tranny. |
| Author: | Joug_Fin [ Mon Oct 04, 2004 4:09 pm ] |
Thanks Craig. So are all torque converter's as weak or is there any better one's? |
| Author: | Dart270 [ Tue Oct 05, 2004 8:15 am ] |
It is unusual to see a stock one split on a stock motor, though. Get a TC with an "alloy" or 4340 or 4330 pump drive hub. That will hold up. Get them to radius the slots in the hub also. You can have a new alloy hub welded onto your TC, but it might be worth it to buy a new one. I've split a few, but only on built motors, and only the non-alloy hubs. Lou |
| Author: | Joug_Fin [ Tue Oct 05, 2004 3:10 pm ] |
Hi Lou After doing little research here in finland, it's very usual that these TC's are having those cracks. Maybe it due to cold winters. Anyway I found new one and hopely get it tomorrow. I also found few broken ones, which confirms that it is very usual with stock engine's. |
| Author: | Joug_Fin [ Mon Oct 25, 2004 2:06 pm ] |
Now few weeks later with new TC There has been some vibration. Is it possible that i have done somenthing wrong?? Vibration has come stronger now. When I assembled TC to driveplate, there was only one position when all bolts fitted. |
| Author: | sixinthehead [ Mon Oct 25, 2004 2:24 pm ] |
Can you get it to vibrate in neutral by reving the engine with the car stopped? This will narrow it down to the engine/converter. Otherwise, start looking at the whole driveline, like u-joints and such. It's possible you got a weighted converter from a 360. They were externally balanced, but I can't remember for sure if the weights were on the flexplate or the converter. Can anyone clarify this? |
| Author: | kesteb [ Mon Oct 25, 2004 2:45 pm ] |
For a 360, the weights are on the converter. |
| Author: | Joug_Fin [ Mon Oct 25, 2004 6:02 pm ] |
This is not balanced converter. There is little vibration in neutral, when I slowly higher RPM. I also thought that it may come from U-joints. When driveline was out I greased U-joints. I also replaced pinion seal on 7 1/4 and i'm not sure about tightening the nut. Manual says that first check torgue of rotating pinion shaft. The torgue was very low, so that it was impossible to at measure. I tried to tighten it same position that it was. What about if it is too tight? Some topic there was that if lockup is going bad it can cause vibration. What that mean. I have rebuild lockup conventer. Is that kind of problem in TC or in tranny? |
| Author: | sixinthehead [ Tue Oct 26, 2004 6:22 am ] |
The pinion has a crush sleeve to set bearing preload, so that torque is very important. However, problems there would probably make a noise, not just a vibration. A slipping lockup can make a shudder when under load (climbing hills). This can result from a bad converter, or supply problems like pump or valve body leaks. Is the vibration vehicle speed sensitive or load sensitive? |
| Author: | Slant6Ram [ Tue Oct 26, 2004 9:24 am ] |
| Post subject: | More. |
Quote: I also replaced pinion seal on 7 1/4 and i'm not sure about tightening the nut. Manual says that first check torgue of rotating pinion shaft. The torgue was very low, so that it was impossible to at measure. I tried to tighten it same position that it was. What about if it is too tight?
As stated, there is a disposable crush sleeve between 2 pinion bearings. Torque is critical for gear wear and alignment. You might even need to rebuild the whole thing, or at least check your wear pattern with some marking compound. I suggest you fix the rear before you move on to any other repairs.The lock up action is a hydrolic funtion which can be adjusted by a spring in the transmission valve body. (I think that's what I've read) I think the change can be made while the transmission is still in the car, IF it's the problem. |
| Author: | Joug_Fin [ Tue Oct 26, 2004 9:25 am ] |
The vibration starts getting stronger when driving 45-50. Also when testing neutral, the vibration is very strong at ~1000 Rpm. Is it possible that TC is not assembled correctly to the driveplate?? I was not able to put it to other position. Bolts fitted only in one position. |
| Author: | Joug_Fin [ Thu Oct 28, 2004 9:15 am ] |
After checking and testing more, everything seems to be assembled correctly and I'm quite a sure that problem is that TC. The vibration is quite strong with every gear while driving 1000-1800 Rpm. If anyone has any ideas for more checking or somenthing else that may cause this problem let me know. I really wouldn't like to do everything twice if it is not necessary. Also one thing, I have never noticed when lockup is contacting, not with this or old converter. |
| Author: | Super6 [ Thu Oct 28, 2004 9:42 am ] |
If it is a stock replacement converter, the RPM's you describe having the most vibration is below the stall speed of the TC, which leads me to think the problem is the TC itself (defective). Have you checked all of the flex plate bolts to see if they have backed out (did you use loc-tite when installing them?) -S/6 |
| Author: | Joug_Fin [ Thu Oct 28, 2004 9:45 am ] |
Deja vu S/6 ?? |
| Page 1 of 2 | All times are UTC-08:00 |
