truck flywheel
https://slantsix.org/forum/viewtopic.php?t=10614
Author:  sixty4dartgt [ Sat Oct 09, 2004 6:35 pm ]
Post subject:  truck flywheel
As far as the slant 6 truck flywheels go, how many different ones were made?
I thought the truck had a 11" 143 tooth wheel.
I heard someone said their truck flywheel, with a 2 1/8 crank ID, had 132 teeth.
Anyone heard of that?
Does anyone know what the crank ID is on the 11" truck flywheel? :?
Author:  DusterIdiot [ Sat Oct 09, 2004 8:10 pm ]
Post subject:  There are two...
Behind the later OD trannies those come with a standard size flywheel like in the cars, but are heavier for torque and come with the 10" clutch. If you get one with a low mount starter and a straight 4 speed in early trucks or a NP235/435 it should be a larger 11" clutch unit.
Author:  Doctor Dodge [ Sun Oct 10, 2004 10:41 am ]
The 143 tooth NP 435 flywheels I have seen all had the small crank hole. .(60-67 SL6)
This large flywheel can only be used with the matching bellhousing that has the low V8 starter position. (and it weighs a lot)
Author:  DusterIdiot [ Sun Oct 10, 2004 10:14 pm ]
Post subject:  And beyond...
Last year I sold one out of an 80's truck to a member in Washington for his Ramcharger project that needed the special bell and flywheel, so they did make them for the larger crank pocket.
Author:  VDART [ Mon Oct 11, 2004 4:23 am ]
Post subject:  flywheel stuffing
Hello, been reading this post, I just sold an 11" flywheel, & the bellhousing (seperate buyers). The bellhousing was aluminum & it came from a 1960 Valiant, appearing to be original. Just FYI
Author:  kesteb [ Mon Oct 11, 2004 3:30 pm ]
I have a complete 11" setup out of a '80 1/2 ton. The bellhousing is setup for a 3 speed or the granny low 4 speed.
Author:  sixty4dartgt [ Mon Oct 11, 2004 10:32 pm ]
Do you know how many teeth on the '80 1/2 ton?
Has anyone heard of a 132 tooth flywheel (factory)?
